976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 25, 2026, 02:48 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tange MX 2 Headset
Author Topic: Tange MX 2 Headset  (Read 3495 times)
curtispro
Tange MX 2 Headset
« on: June 29, 2011, 09:39 AM »
I just got one of these for my DP build, and like the other 2 headsets I have tried it doesn't fookin fit, threaded parts go on about 1/2 inch then gets tight, the original old headset fits a treat but it is not going back on as its past its best, threads on the forks are perfect, it must be a TPI issue  :crazy2: :crazy2: :crazy2: :crazy2: :crazy2: :crazy2: :crazy2: I am getting fed up now  :(
1mancity2
Re: Tange MX 2 Headset
« Reply #1 on: June 29, 2011, 10:06 AM »
Have you got another pair of forks to try the headset on?
curtispro
« Reply #2 on: June 29, 2011, 10:21 AM »
Yes I tried the new headset on the Mrs fake Haro FST and it fits fine (its a early 90's diamondback) I can't understand it.
I have got one of these coming from pork chop
http://www.porkchopbmx.com/Alloy-BMX-headset-1-threaded-w-325mm-cups-RED-ANODIZED-HSIMH6713.htm
1mancity2
« Reply #3 on: June 29, 2011, 10:37 AM »
Have you tried the old lock nut on those forks?
curtispro
« Reply #4 on: June 29, 2011, 10:56 AM »
No I haven't, will strip it back down and give it a try, but still wont help with the DP  :'(
1mancity2
« Reply #5 on: June 29, 2011, 11:43 AM »
But at least you will know its a tpi issue and not your forks  :daumenhoch:
« Reply #6 on: June 29, 2011, 07:13 PM »
where did you get it from? I've just got 2 new ones and tried them on a few pairs of forks, work fine on all of them.
curtispro
« Reply #7 on: June 29, 2011, 11:22 PM »
Derekonlinecycles tange mx2, tried the one off original headset on the fake FST and it don't fit, they are original DP GL forks, but I can't seem to get a fookin headset to fit it  :'( :tickedoff:  >:( :'( :-\
1mancity2
« Reply #8 on: June 30, 2011, 07:13 AM »
Its either a different tpi or the original could be cross threaded and so are your forks now, could you restore the original?
Offline rick1970
« Reply #9 on: June 30, 2011, 07:27 AM »
Hi mate take them forks to your local bike shop he will tell you your problem in 5 minutes  :daumenhoch:
