mini BB removal
<< < (4/4)
diesel:
Cheers Mark, will give you a shout
The spindle is 125mm
The Bottom Bracket measures 65mm
Anyone any ideas what might fit this?
1mancity2:
Diesel have a look on here,
http://www.parktool.com/blog/repair-help/bottom-bracket-tool-selection
Dark Diggler:
--- Quote from: diesel on June 30, 2011, 09:05 PM ---Cheers Mark, will give you a shout
--- End quote ---
I would say that the BB you have in there aint for single speed but for a triple, that spindle width would put the chainline out by a mile, as for the shell width 68mm should be fine.  Have you tried some cranks on there to see how it shapes up?
diesel:
--- Quote from: Dark Diggler on July 01, 2011, 10:55 AM ---
--- End quote ---
--- End quote ---
I have some nice 165 cranks for it and they seem to line up fine, although now that you've said that I'm going to double check.
I had a chat with SBD a little while ago about masking it for spray - So I'm thinking I might risk it in the oven with the BB attached
As It works well I'm not sure I really want to thinker about with it too much.....  ???
1mancity2:
Wet paint it no need for the oven then  :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
