976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 08:20 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  where do you put it ?
Author Topic: where do you put it ?  (Read 3311 times)
« on: June 30, 2011, 09:42 AM »
right got this in a box of stuff from a mate - he doesn't know what it is - now i assume that it is a stem clamp ?
but just tried to put a stem inside it and it doesn't fit ?
so who knows what and how it is
which way up and what to do with it
is it a seat clamp instead ?
PEARL made
missing nut bolt
has a tiny screw to lock down
80's 90's ?
cheers B   ;)
Re: where do you put it ?
« Reply #1 on: June 30, 2011, 10:17 AM »
seatclamp to use a slightly smaller seatpost on???
RoyalTrux
« Reply #2 on: June 30, 2011, 10:45 AM »
Headlock/Stem reinforcer?
Offline diesel
« Reply #3 on: June 30, 2011, 11:23 AM »
looks like its off a shop clothes display not a bike....
just my guess
trasher
« Reply #4 on: June 30, 2011, 11:53 AM »
looks like it would be more suited to drum set or microphone stand  :2funny:
http://drumsetsforsaleonline.com/wp-content/uploads/2010/04/drum-set.jpg
id say the clamp goes around a larger tube  ,allowing a smaller tube to slide up and down the larger one and then to be locked off by the grub screw
« Last Edit: June 30, 2011, 12:11 PM by trasher »
« Reply #5 on: June 30, 2011, 12:28 PM »
who mentioned drumkits??
Pearl are one of the largest manufacturers!!!!
Question is, can bendy make it work?? I bet he can!!
Offline Discostu
  • Two's Company
« Reply #6 on: June 30, 2011, 12:37 PM »
Now this is an easy one bendy. It's part of a drum kit. I would say it's for a symbol stand. Pearl make drum kit me old mate. But u can fit it to ya burner if u want :LolLolLolLol:
Offline Discostu
  • Two's Company
« Reply #7 on: June 30, 2011, 12:46 PM »
I've just thought. If you do attach it to your burner for the next bike ride you could attach a high hat instead of having the siren! :2funny: give us a crash  :LolLolLolLol:
« Reply #8 on: June 30, 2011, 12:59 PM »
So thats bendy's problem sorted, now how do i fit these super lightweight layback seatposts
bought a job lot so get dibbing
« Reply #9 on: June 30, 2011, 02:06 PM »
 ;D
« Reply #10 on: July 01, 2011, 12:24 AM »
 ;D
this came from a mates shed of bike parts, i had the bmx bits and saw this - i had seen a couple of seat clamp stem clamps types - so i thought it was one and tried it for size, it was too small so that was the first clue  ;D but i thought i might as well ask you lot
to a drummer it is obvious  ;D
cheers all  :D
« Reply #11 on: July 01, 2011, 08:12 AM »
;D
cheers all  :D
I challenge you to make it work bendy, if anyone can you can! This thread put a smile on my otherwise miserable face recently. cheers fella
adeshere
« Reply #12 on: July 04, 2011, 12:50 AM »
I wonder if its to use a standard size seat post in an origianl raleigh burner that had a larger diameter seat post
ukoldschool
« Reply #13 on: July 04, 2011, 11:23 AM »
facepalm!
« Reply #14 on: July 04, 2011, 01:12 PM »
The bin!  ;D
