976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 04:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Help: Haro RS2 rear brake with 1 1/8 rims!
Author Topic: Help: Haro RS2 rear brake with 1 1/8 rims!  (Read 3042 times)
mattuknc
« on: July 23, 2011, 03:48 PM »
Hi All,
Having a few issues trying to get the rear brake/ rim lined up. On these photos there's no freewheel, but I don't think that would have any effect!
Basically because these rims are so narrow there doesn't seem to be enough adjustment on the brake pads?!
Any ideas?!
Matt
Offline oldtired
  • Dirty Old Man
Re: Help: Haro RS2 rear brake with 1 1/8 rims!
« Reply #1 on: July 23, 2011, 03:56 PM »
are you going to riding /racing it?  put smaller caliper on it somthing like a road bike calliper with shorter arms .. you'll be able to sit the axle centre in the dropout then , shorter/ smaller caliper will work better too , mx 1000 type realy on work well down to 1.5 rim, other option is newer blocks with the toe in spacers on but i looks like you might stuggle getting em to alighn up on the rim with that caliper
« Last Edit: July 23, 2011, 04:08 PM by oldtired »
RoyalTrux
« Reply #2 on: July 23, 2011, 04:07 PM »
You need a mini brake set up.
I have mini shimano calipers if you want.
pm me.
Offline john4130
« Reply #3 on: July 23, 2011, 04:09 PM »
if that's an mx 1000 you got on it you could try an mx900. it's a little bit shorter and may reach better. not sure what these came fitted with, maybe a bulldog brake?
Offline 58 delray
« Reply #4 on: July 23, 2011, 07:39 PM »
try a 901  :daumenhoch:
Offline Jon The Bassist
« Reply #5 on: July 23, 2011, 08:06 PM »
you're gonna need mini-callipers for that to work properly.
Offline glenboy
« Reply #6 on: July 23, 2011, 08:08 PM »
got this weinnman 730 mini brake £10 posted matt  :daumenhoch:
Offline sawzall
« Reply #7 on: July 23, 2011, 08:10 PM »
i have a nos weinmann 730 in blue anno if you are interested ???
mattuknc
« Reply #8 on: July 23, 2011, 08:22 PM »
It's ok guys, now sorted. Thanks Rad rat.  :daumenhoch:
mattuknc
« Reply #9 on: July 30, 2011, 06:11 PM »
Cheers radrat, it fits a treat and looks good to boot.  :daumenhoch:
« Reply #10 on: July 31, 2011, 05:29 AM »
Looks way better, just need to adjust the brake pads otherwise you're going to catch the tyre :)
mattuknc
« Reply #11 on: July 31, 2011, 06:57 AM »
I think that's just some photo trickery, it's all setup ok.  :daumenhoch:
