976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 07:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What headset do i need to use with a DK headlock ????
Author Topic: What headset do i need to use with a DK headlock ????  (Read 2037 times)
Offline southern andy
« on: July 25, 2011, 10:20 AM »
I've got a nice DK Headlock which i'd like to use rather than sell/store it but i'm struggling to find a headset with has a flat bit so the lock fits flush.
As you can see from these two headsets here they both seem to have a fixed bolt to them which then causes the problem.
The DK headlock has it's own thread which screws on to the fork thread.
looks like this which doesn't work.
Help  :)
« Last Edit: July 25, 2011, 12:06 PM by Southern Andy »
Offline Glynnyboy
Re: What headset do i need to use with a DK headlock ????
« Reply #1 on: July 25, 2011, 12:46 PM »
The early basic tange ones that appeared on the Raleigh burners are what you need.
Give butts a pm on BW chances are he will have some rechromed ones available.
http://www.burnerworldforum.co.uk/viewtopic.php't=16179
It looks like your lock would replace the existing washer and top nut on one of these nicely.
« Reply #2 on: July 25, 2011, 01:46 PM »
Cheers Glynn,
so removing the top nut and washer, the remaining parts of the headset would be completely flat so my H/L above would sit on there perfectly ?????
What about the GT Epoch ?????
« Reply #3 on: July 25, 2011, 02:58 PM »
does the the dk headlock not just replace the nut?
« Reply #4 on: July 25, 2011, 05:02 PM »
yes Dave mate but as you can see in the bottom picture it sits proud rather than flat to the top of the headset, this is because picture 4 has the raised teeth bit. If they weren't there it would work. sadly that actual headset needs that bit hence why i need a flat one.
« Reply #5 on: July 25, 2011, 05:04 PM »
think i have a spare top part for a headset andy. yours if you want it mate
« Reply #6 on: July 25, 2011, 05:10 PM »
It's the picture 4 bit i need Dave but need to be flat or even inverted. That then screws on to the forks to seal the bearings in and then the headlock screws down on to that and it's tightened up to lock it all.
You going to MK ????
« Reply #7 on: July 25, 2011, 05:14 PM »
yes its flat im sure it is. its like a standard tange not the beartrap type pictured
its yours at mk but ffs remind me to bring it  :daumenhoch:
« Reply #8 on: July 25, 2011, 05:31 PM »
Cheers Dave, you're a good man. It's not true what Wardy says about yer.  :4_17_5:
