What no of teeth do I need on my freewheel?
<< < (2/2)
brettypeeps:
Compare left and right hand side of rear hub :daumenhoch:
There is quite a size difference so should be quite obvious but if you are going for a 16 teeth you wont go far wrong.  :4_17_5:
Tuffs have the larger size
Threaders:
Hub only has a thread on one side and looks to be the smaller version. I normaly get stuff on here or the bay as my local bike shop only do cheapo parts.
Glad I asked the question before just going ahead and buying one. Ive already had a nightmare getting a 28tpi bb for this build (1mancity2 helped me out on that) how about the suntour 17t freewheel??
Cheers, Jonathan :daumenhoch:
brettypeeps:
It is definately the larger on.  if it was my money I would go for one of these and stick to a 16 teeth  or else you will be pedalling quite fast.
http://www.ebay.co.uk/itm/DICTA-Freewheel-BMX-Sprocket-16t-BRAND-NEW-CHROME-/140473924873?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item20b4e5fd09 Cheap
http://www.ebay.co.uk/itm/Shimano-MX30-Single-Speed-Freewheel-Sprocket-BMX-16-T-/260820447223?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3cba1c2ff7 Not so Cheap but pretty.
Both of them will fit your tuffs :daumenhoch:
Threaders:
Cheers brettypeeps. Just seen a second hand shimano mx30 for 15 quid, so might get that.
Thanks for your help and advice :daumenhoch:
brettypeeps:
--- Quote from: Threaders on July 29, 2011, 01:58 PM ---Cheers brettypeeps. Just seen a second hand shimano mx30 for 15 quid, so might get that.
--- End quote ---
Navigation
[0] Message Index
[*] Previous page
Go to full version
