976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 05:16 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What no of teeth do I need on my freewheel?
Author Topic: What no of teeth do I need on my freewheel?  (Read 2726 times)
Threaders
« on: July 29, 2011, 12:18 PM »
Hi people,
Just need some acvice on getting a freewheel. I will be using new tuffs on a 1990 gt mach one build and have a sugino 45 tooth chainring with tioga spider.
seen suntour freewheels on the bay which have 16t 17t and 18t. Which one do you guys reckon I need.
Ta very much :daumenhoch:
Re: What no of teeth do I need on my freewheel?
« Reply #1 on: July 29, 2011, 12:21 PM »
16 teeth is what i use with a 44 or 45 chainring :daumenhoch:
« Reply #2 on: July 29, 2011, 12:24 PM »
16 for me too, although if you're going to rie it distance a 15 will give you a better top speed
« Reply #3 on: July 29, 2011, 12:26 PM »
You will stuggle getting a 15T to fit new tuffs... Works with any brand 16 tooth or larger freewheels.  Also works with AC brand 15 tooth freewheels.
http://www.planetbmx.com/shop/skyway-tuff-wheels/20-wheels/20-blue-skyway-tuff-2-wheel-set/prod_2.html
« Last Edit: July 29, 2011, 01:00 PM by brettypeeps »
Threaders
« Reply #4 on: July 29, 2011, 12:33 PM »
I can only see ACS, Dicta or shimano's in 16t (although there are some cheapy ones as well) If its going to be ACS, how will I know which size to get?
Thanks, guys :)
« Reply #5 on: July 29, 2011, 01:10 PM »
Compare left and right hand side of rear hub :daumenhoch:
There is quite a size difference so should be quite obvious but if you are going for a 16 teeth you wont go far wrong.  :4_17_5:
Tuffs have the larger size
Threaders
« Reply #6 on: July 29, 2011, 01:31 PM »
Hub only has a thread on one side and looks to be the smaller version. I normaly get stuff on here or the bay as my local bike shop only do cheapo parts.
Glad I asked the question before just going ahead and buying one. Ive already had a nightmare getting a 28tpi bb for this build (1mancity2 helped me out on that) how about the suntour 17t freewheel??
Cheers, Jonathan :daumenhoch:
« Reply #7 on: July 29, 2011, 01:48 PM »
It is definately the larger on.  if it was my money I would go for one of these and stick to a 16 teeth  or else you will be pedalling quite fast.
http://www.ebay.co.uk/itm/DICTA-Freewheel-BMX-Sprocket-16t-BRAND-NEW-CHROME-/140473924873?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item20b4e5fd09 Cheap
http://www.ebay.co.uk/itm/Shimano-MX30-Single-Speed-Freewheel-Sprocket-BMX-16-T-/260820447223?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3cba1c2ff7 Not so Cheap but pretty.
Both of them will fit your tuffs :daumenhoch:
Threaders
« Reply #8 on: July 29, 2011, 01:58 PM »
Cheers brettypeeps. Just seen a second hand shimano mx30 for 15 quid, so might get that.
Thanks for your help and advice :daumenhoch:
« Reply #9 on: July 29, 2011, 02:04 PM »
