976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 04:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Have I shagged my Kashi?
Author Topic: Have I shagged my Kashi?  (Read 1999 times)
punkdSICO
« on: July 30, 2011, 11:39 AM »
Ooops..  My Kashi restore is not going too well:
Rubbed out all the scratches with some 180 paper and it actually looks pretty good apart from the powdery/patchy appearance.  Despite this, I dyed it anyway hoping it would still come good but, it looks pretty much the same as before dying..
Any tips would be very appreciated..
thanks,
Paul
Re: Have I shagged my Kashi?
« Reply #1 on: July 30, 2011, 11:45 AM »
what dye you use  ???
punkdSICO
« Reply #2 on: July 30, 2011, 11:49 AM »
Dylon Ocean Blue.  I added about 400g of salt, in boiling water (on a plastic bowl so could not maintain the heat).  Left it for a good 1.5+ hours.
Ta,
Paul
« Reply #3 on: July 30, 2011, 11:49 AM »
It looks like the dye you've used is of a lower pigment than the original seat colour. Did it change colour at all?
motomagII
« Reply #4 on: July 30, 2011, 11:53 AM »
rit dye instead of dylon and tad darker colour at a guess
Offline GTnumber1
« Reply #5 on: July 30, 2011, 12:09 PM »
you need to get rid of all those coarse 180 marks, cos what ever colour you dye it the marks will come thru  :daumenhoch:
sid1972
« Reply #6 on: July 30, 2011, 12:17 PM »
same as the above - fine grades etc down to like a 1200/1800.. then rit with loads of salt..
you can polish plastic to with a nice cutting compound but try this after the dye, You can pull that back because I have done worse.  ;)
« Reply #7 on: July 30, 2011, 01:30 PM »
right what has happend here is the wrong dylon - i'm guessing it was a cold dye and not a MP (multi-purpose) and no fixer !
only MP dylon dyes will dye it due to the nylon in it
madonna blue will work
« Reply #8 on: July 30, 2011, 03:07 PM »
I have 2xMadonna blues that i've had for a while that I was gonna use on some Tuffs, if you pm me your addy I can send them to you on Monday or bring them to MK next week??
