9/16 pedal...whats the Thread pitch?
Gnarlyscoots:
If it's 20 TPI, then divide 20 threads by 25.4mm. That will give you the MM you need :daumenhoch:
That works out 0.78mm per thread.
Not sure if that helps ya :-\
steve69:
--- Quote from: Londonhellboy on August 07, 2011, 11:51 PM ---If it's 20 TPI, then divide 20 threads by 25.4mm. That will give you the MM you need :daumenhoch:
--- End quote ---
You won't be able to get m12 x 0.78
It's NOT metric
The 'pitch' is 20 threads per inch (9/16" x 20tpi)
Gnarlyscoots:
French pedal spindles use M14 x 1.25 (14 mm/0.55 in metric diameter with 1.25 mm or 0.049 in pitch) threads, and thread loosely into a 9/16 pedal hole.
stidds:
You can also cut the correct threads for pedals on the heli-coil, I have a set of 9/16 pedal taps (left and right tap) that you can use if you need them.
Taipan:
thx stidds,maybe sorted,but if not i'll get back to you with your kind offer :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
