976298 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 22, 2026, 09:02 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rear Nippon conversion??
Author Topic: Rear Nippon conversion??  (Read 3002 times)
« on: August 29, 2011, 11:50 AM »
Can i convert this rear nippon to a Potts Mod front?  maybe changing the adjuster bolt and the lttle bit at the quick release that the cable sits into?  can it be done?
Offline wildon
Re: Rear Nippon conversion??
« Reply #1 on: August 29, 2011, 11:52 AM »
I've got a new dc pots mod quick release that you could swap with that one  :daumenhoch:
« Reply #2 on: August 29, 2011, 11:53 AM »
you sure it can be changed?  the actual quick release is rivetted on....or do you mean the little bolt on part?   :daumenhoch:
« Reply #3 on: August 29, 2011, 11:57 AM »
old qr is cut off and the potts mod qr fitted
the adjuster is different for a front as well rob
both the above parts are available at porkchops
alternatively just cut off the qr and fit a cable guide. take off the adjuster and set it up as you would an fs880 caliper
you will need a longer spindle as well
get a bulldog front for 9.99 and swop all the parts maybe  :-\
Offline wildon
« Reply #4 on: August 29, 2011, 11:58 AM »
grind off the rivit and press the new one in.  I can do it for you if you like .. i use a friends industrial press  :daumenhoch:
i have a spare one of these .. http://porkchopbmx.com/Dia-Compe-replacement-quick-release-for-front-brake-1008304.htm
then you just need one of these .. http://porkchopbmx.com/Dia-Compe-Brake-Adjuster-FRONT-883QLADJ.htm
« Reply #5 on: August 29, 2011, 12:02 PM »
The spindle is fine as it's going on a set of LG's so the rear spindle is just the right length.
Wildon, PM me with details and how much you want for the work and if no one wants a trade then i will take you up on your very kind offer  :daumenhoch:
« Reply #6 on: August 29, 2011, 12:13 PM »
You don't need to drill, cut or fook anything up to convert it to a front:
New one from Porkchop
Unbolt the micro adjuster and bolt on a one from Porkchop then feed the cable through the QR mech up to the newly fitted adjuster which has a cable pinch olt on it  :daumenhoch:
OR you could just take off the micro adjuster and put the pinch bolt there and lose the ability to adjust cable tension  ;)
« Last Edit: August 29, 2011, 12:17 PM by MartyC »
« Reply #7 on: August 29, 2011, 12:18 PM »
So Marty, you're saying i don't need a new QR just a new adjuster bolt from Porky?
Offline wildon
« Reply #8 on: August 29, 2011, 12:22 PM »
the quick releases are different front and rear.  how would the cable slide through it?  you'd have to leave the bolt loose.  it'd be a bodge job and the nut would work loose and fall off
« Reply #9 on: August 29, 2011, 12:27 PM »
thats what id say as well terry
the qr on the front has like a cable guide fitted
« Reply #10 on: August 29, 2011, 12:30 PM »
i'm sure the QR is diferent Marty, i will check out the front on my other street beat later  :daumenhoch:
Offline Del
  • Re-living my youth!
« Reply #11 on: August 29, 2011, 12:31 PM »
as Terry says, the QR is different
ozone
« Reply #12 on: August 29, 2011, 12:54 PM »
I've done this before and the solution is really easy.  Remove the anchor bolt that (secures the cable) from the QR and get a pear shaped ferrule and put that in the hole were the bolt used to go.  (this holds the outer cable in place like a proper front Nippon QR does - then the inner cabe is clamped by the new Porkchop QR)  It was a while ago when i did mine so I can't remember if the ferrule need a little fettling with a file so it fits snugly in the QR assembly but it definitely does the job.
Ferrule
http://www.ebay.co.uk/itm/Brake-Lever-Clarks-Alloy-Cable-Ferrules-VINTAGE-10-99p-/170686374647?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item27bdb362f7
« Reply #13 on: August 29, 2011, 01:49 PM »
Ferrule
WHS ^^^
Offline HUTCHMAN
« Reply #14 on: August 29, 2011, 01:58 PM »
http://www.radbmx.co.uk/forum/index.php'topic=7566.0
Have a look at Fuzzynod's.(2nd and 3rd pic)
Hope that helps.
