976298 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 10:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline 400 non driveside pedal stuck !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Author Topic: Redline 400 non driveside pedal stuck !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  (Read 5632 times)
Offline crazycraig
 :wtf: :wtf:  :wtf: am i going going to do ?
I have a suntour XC spindal stuck in and cant get it out for nothing . I have soaked it in WD , I have had it in the vice with no joy .
Any ideas ? ? ? ?
Old School BMX only
Cash is King
Offline wildon
you tried heating and rapid cooling it?
Offline Betty
Soak it in diesel...  :daumenhoch:
2 minutes turkish...
Offline crazycraig
No i have not wildon . Do you suggest heating the spindal or the crank arm ?
Old School BMX only
Cash is King
Offline crazycraig
I have soaked it in WD would that not be better than diesel ?
Old School BMX only
Cash is King
Turn it the other way ? might sound strange but you might be tightening it ? just a thought  ???
Offline wildon
i'd heat the spindle as it might cause some damage to the chrome on the arm.  seen someone do it on youtube where he heated it with a blow torch then dipped it in ice water and repeated that a few times  :daumenhoch:
Offline Betty
That was diggler's advice to a similar problem.... sprocket bolt seized
Must admit i've not tried it... sprocket's still stuck to the crank arm...  ;D
Offline diesel
I've had this before:
Buy a long pedal spanner, put the spanner and the crank down so that they make a upside down V (^) raised from the floor you might need to get someone to hold them or prop them with their foot.
press down with your foot on the top of the 'V'
Remember that pedals always tighten in a forward motion, so that when you pedal the pedal is kept tight.
That means that the non-drive side will untighten clockwise if you are looking at it side on.
Offline crazycraig
Think i may try the heat route ..........
Whats the worst case scenario here .......... I end up with an Andy Patterson JMC with suntour XC's on or even worse lose a crank set  :'(
Old School BMX only
Cash is King
Offline crazycraig
Thanks for the advice chaps .......... I am hoping someone else will offer to do it ........So i can blame someone else  :D
Old School BMX only
Cash is King
i'll do it for you :D
try coke~a~cola - it will eat the rust and not just slip past it - half an hour in and then try the long crank spaner on the floor and put weight on it  ;)
Offline jT Racing
  • i like bikes. :/
You are undoing it by turning it clockwise Craig?
Vice on the spindle, rubber hammer on the arm otherwise.
ding dong
Offline crazycraig
Old School BMX only
Cash is King
Rodgy1970
Good idear
Vice in spindle scaffolding bar over crank = leverage
If the spindle slips round weld a bolt or bar across it.
Try boiling water for heat.
SMASHHHHHHHHHHHHHHHHH ITTTTTTTTTTTTTTTTTTTTTTTTTTT  :knuppel2:
salt mends everything  :crazy2:
trasher
If You heat the spindle then the spindle will expand
It's the crank you need to expand so the spindle comes out
Offline rick1970
Rule number 1 ;  Always grease your threads before fitting  :D
Offline Bigplinky
Ring a local Engineering company they may be able to freeze it out for you (costs but works better than heat) or get it drilled out by somebody who knows what they are doing
Offline crazycraig
I will have a do when i get home at the weekend and report back !!!! Thanks again fellas  :daumenhoch:
Old School BMX only
Cash is King
Offline jT Racing
  • i like bikes. :/
If you struggle, drop it off at mine and I'll sort it at work.
ding dong
