976296 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 08:26 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Resto advice for yellow (steel hubbed) Tuff II's
Author Topic: Resto advice for yellow (steel hubbed) Tuff II's  (Read 3018 times)
Offline Chromo Buzz
« on: October 11, 2011, 10:40 PM »
Evening chap's,
Hoping you guy's can point me in the right direction on a dilema i have :-\.......i spotted some yellow tuff's on Ebay.com late one night for a BIN price that was too good to turn down (though no Int. shipping), though i believe if you dont ask you dont get. Emailed the seller  & he said yes (top bloke) :daumenhoch:, they arrived in 1 week from the states & no custom's charge which was a result!! My dilema is do i dye them (yellow) or after reading another thread on here do i get them aqua blasted??
Here's the  one's from the state's
In the photo's they look pretty sweet, i want to put these on a carpet queen  so they need to be 10/10
Now about 8 months ago i had another pair of yellow tuff's which were faded so i went down the dyeing route, though stupidly i read  a thread on here wrong & put 3pkt's of dye instead of 2....doh!! They went from this to this Then tried dyeing them to red & fooked up, so they are gonna be black now. Dont wanna screw these one's up, so any advice would be greatly appreciated :daumenhoch:
sid1972
Re: Resto advice for yellow (steel hubbed) Tuff II's
« Reply #1 on: October 11, 2011, 10:46 PM »
I would try the less aggressive option first - the old dish washer..
If that fails - very, very fine wet and dry paper to remove the discolour and some good neutral boot polish.
and then Aqua blast if its not the result you want - I can give you the details of the chap I used in my thread.
if that does not do it dye em.
« Reply #2 on: October 11, 2011, 11:28 PM »
simple - try bleaching them - the colour should fade out if it's not had a fixer added - won't hurt to try - will need to polish up metal parts after - couple of days in a check regularly
cheers  B  ;)
ukoldschool
« Reply #3 on: October 12, 2011, 09:10 AM »
I think hes after advice on what to do with the yellow tuffs he's just bought rather than the other ones which he's already fecked up :)
« Reply #4 on: October 12, 2011, 10:18 AM »
my mistake  :D
if you dye them used DYLON DYE / GOLDEN GLOW x 2
the orange one's will dye to red if you want - you just need to get the technique right and use the right stuff
here's a quick way of doing it
the Gorden Ramsay way of dying wheels [/size]
take 1 set of OGK's - slightly faded
wash
pick out any dirty bits missed
scrape off any brake marks
bleach
hot water
salt
dye
put in and leave for 24 hours - turning and stirring every so often
cover
take out and wash in cold water - then dry
now ready to serve - i mean ride - DONE
cheers B[/size]
« Last Edit: October 12, 2011, 10:20 AM by BENDYCAT ELEVENTEEN »
« Reply #5 on: October 12, 2011, 09:25 PM »
great result there bendy :daumenhoch:
my mistake  :D
wash
bleach
hot water
salt
dye
cover
cheers B[/size]
Offline Chromo Buzz
« Reply #6 on: October 12, 2011, 09:55 PM »
You were spot on mate, it was the new one's i needed the advice on :daumenhoch:
Offline Chromo Buzz
« Reply #7 on: October 12, 2011, 10:05 PM »
Excellent work on those OGK's Bendycat :smitten:, it was your thread i followed last time but i fecked up on by putting one too many packets of the dye in the pot :uglystupid2:
 They ended up like this when i tried  dyeing them red
I'm gonna dye  these  black now, they will go on an 85 Sport (future build) f/forks powdered in yellow with black components, So all is not lost :)
Thanks again guy's for your advice ;) :daumenhoch:
« Reply #8 on: October 13, 2011, 01:51 PM »
I can only guess that it is where you get a top layer on skyway mags - this looks faded and mostly on the inside of the spokes and not the spines of the spokes so to speak - it looks like a layer of dust that won't move
when doing up skyways you some times have a load of this on them - this needs to be removed or it can show up after a dye as dark patches
I guess you have three things to try here - sand them down again and this will take a long time with hard work - or auqa blast them but cost big money or dye them black and polish up the hubs to a good finish to make them look good
