976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 07:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  hoffman condor - colour advice (no longer) needed - (more) pics added - FINISHED
Author Topic: hoffman condor - colour advice (no longer) needed - (more) pics added - FINISHED  (Read 15353 times)
Offline BrianP
ok folks, this is gonna be my first project of the summer.
close to mint structurally, aside from a bit of one drop-out missing due to ledge grinds - soon to be sorted with a welder and a bit of filler metal.
big question i need answered is - anyone know what (other) colours this frame came in?
got a NOS set of (era-correct) decals ready to apply after painting, but don't reckon i'm gonna go with trying to replicate the metallic / candy apple red type colour the frame was originally.
any suggestions?
Bp.
« Last Edit: August 14, 2006, 12:06 PM by brianp »
Re: hoffman condor - colour advice needed
« Reply #1 on: May 31, 2006, 09:16 AM »
be original do your own colour scheme if you arnt going to do the normal colour let your hair down
and do a stunner :daumenhoch:get ideas from museum.
Offline BrianP
« Reply #2 on: May 31, 2006, 09:38 AM »
Hmm, got a set of orange tyres from ftobmx  :daumenhoch: and some NOS mushy's in orange arrived from the states this am...
feel a black and orange scheme coming on...
« Reply #3 on: May 31, 2006, 09:43 AM »
go for it  :daumenhoch:
« Reply #4 on: May 31, 2006, 12:56 PM »
have you seen the loverly blue one in the museum.....btw where did you get that frame, and what year is it?
Offline Stodgy
    • RADBMX Shop
« Reply #5 on: May 31, 2006, 01:13 PM »
Looks around a 1999/2000 frame...not sure on the colours from that year...what do the graphics look like?
« Reply #6 on: May 31, 2006, 01:15 PM »
I'd go a little earlier - it has the skinnier rear end....  I reckon  earliest 1995,  latest 1999.  I'm not sure when the fatty back ends came in, but I had a 2000 model which was a fatty.   :)
Offline Stodgy
    • RADBMX Shop
« Reply #7 on: May 31, 2006, 01:37 PM »
I don't think the seat tube looks laid-back enough for 95 to 98 - unless it's my eyes playing games on me...
The sticker set would indicate a 98 +, but the red wasn't available in 98 and I believe they went to the more upright seattube in 1999...Rob, I agree with you on the fatty thing for 2000, so I still reckon a 99...(not that it matters - it's sweeeet, and I'm just trying to help identify!) -
1998 Hoffman Condor brochure pic:
Sticker close-up:
Hope this helps!  :daumenhoch:
Dave
« Last Edit: May 31, 2006, 01:41 PM by Stodgy »
Offline BrianP
« Reply #8 on: May 31, 2006, 01:51 PM »
hey guys, cheers for your input.
bought the frame on ebay a coupla years back (bit of an impulse buy, and i don't recall it actually costing that much to be honest) and the same with the sticker set, which looks very like the one on Dave's scan (cheers for that - i don't have any mags from round that time, so it's cool to see)
it's got a 1 1/8" headtube, 14mm dropouts and i'll see what the serial no. is, to try and see what light it sheds, but the seat tube's definitely not very laid-back in comparison to the museum listings.
didn't get any forks with it, but i did get a set of D130 ones from cyclesport a while ago, which i was planning on using with it.
they're of a similar chunky build... and are a sort of metallic green colour, and i'm planning to use the "inspector" on the whole lot...
plus, i'm really wishing i hadn't gotten rid of the HB super stem i had....
i'm in work at the moment, but i'll post a pic of the stickerset later on tonight.
cheers guys,
Brian.
Offline Stodgy
    • RADBMX Shop
« Reply #9 on: May 31, 2006, 02:31 PM »
Hia Brian
Just found the spec for the 1999 Condor...appears the seattube was still 65 degree(?)...went to 68 degree in 2000...anyhow, thought you might like the full spec for re-building (see below)...oh, and colour choice includes the maroon! (2000 was black, white and chrome)
Hoffman  Condor  1999
BB Shell Width: Unspecified
BB Spindle Length: Unspecified
Bicycle Type: freestyle/jumping
Bottom Bracket: Unspecified
Brake Levers: Dia-Tech 99
Brakeset: Dia-Compe 990 brakes, Dia-Tech 99 levers
Chain: KMC 410, 1/2 x 3/32"
Chain Size: 1/2 x 3/32"
Chainrings: 44
Chainstay Length: 14.25-15.75"
Colors: Chrome-Plated, Dark Maroon, Flat Black
Component Group: Not applicable
Crankset: 1-piece chromoly, 44 teeth
Fork Brand & Model: Hoffman Bikes Super Fork
Fork Crown: unicrown
Fork Material: 4130 chromoly, unicrown crown
Fork Rake: 0.0"
Fork Travel: Not applicable
Frame Angles: 74.0 head, 65.0 seat
Frame Construction: TIG-welded
Frame Tubing Material: 4130 chromoly
Front Brake: Dia-Compe 990
Front Brake Lever: Dia-Tech 99
Front Derailleur: Not applicable
Front Derailleur Type: Not applicable
Handlebar: Hoffman Bikes Love Handle Bar
Handlebar Extensions: Not applicable
Handlebar Stem: Hoffman Bikes Super Stem
Head Tube Angle: 74.0
Headset: 1 1/8" threadless Dia-Tech steel w/SST Oryg detangler
Headset Diameter: 1 1/8" threadless
Hub Front: Hoffman Girthy 3/8"
Hub Rear: Hoffman Girthy 14mm
Hubs: Front: Hoffman Girthy 3/8", Rear: Hoffman Girthy 14mm
Largest Rear Cog: Not applicable
Num Rear Cogs: Not applicable
Pedals: Wellgo LU-313U
Rear Brake: Dia-Compe 990
Rear Brake Lever: Dia-Tech 99
Rear Derailleur: Not applicable
Rear Shock: Not applicable
Rear Shock Travel: Not applicable
Rim Front: HB Highroller CP
Rim Rear: HB Highroller CP
Rims: HB Highroller CP, 48-hole
Saddle: HB Velo VL-283
Seat Post Diameter: 25.4mm
Seat Tube Angle: 65.0
Seatpost: HB 4130, 25.4mm diameter
Shift Levers: Not applicable
Sizes: Unspecified
Smallest Rear Cog: Not applicable
Spoke Brand: stainless steel, 2.0mm straight gauge
Spoke Gauge: 2.0mm
Spoke Holes: 48-hole
Spoke Material: stainless steel
Spoke Nipples: brass nipples
Spoke Type: straight gauge
Sugg Retail: 669.99
Tire Front: Hoffman Bikes Skidmark
Tire Rear: Hoffman Bikes Skidmark
Tire Size Front: 20 x 1.95"
Tire Size Rear: 20 x 1.95"
Tires: 20 x 1.95" Hoffman Bikes Skidmark
Top Tube Length: 20.75"
Weight: Unspecified
Wheelbase: 36-37.50"
« Last Edit: May 31, 2006, 02:41 PM by Stodgy »
Offline BrianP
« Reply #10 on: May 31, 2006, 04:19 PM »
cheers dave! that's cool to have.
think flat black's the way it's gonna go...
will post a complete set of b4 and after pics when i get sorted.
thanks again,
Bp.
huffy
« Reply #11 on: May 31, 2006, 04:42 PM »
orange tyres eh brian
  this i gotta see man
  russ :4_17_5:
« Reply #12 on: May 31, 2006, 05:39 PM »
carefull now, or it may end up looking like this.
Offline Stodgy
    • RADBMX Shop
« Reply #13 on: May 31, 2006, 06:43 PM »
thanks again,
Bp.
Pleasure mate - glad I could help. Looking forward to seeing the final build!
Must get round to getting some pics up of mine!  :daumenhoch:
Dave
« Reply #14 on: May 31, 2006, 06:48 PM »
w00t w00t
looking good. funky bars though
Offline BrianP
« Reply #15 on: June 01, 2006, 10:46 PM »
here's a pic of the sticker set i've got ready and waiting.
same as the one on dave's scan, but with a different headtube sticker......?
serial number to follow.
Bp.
« Reply #16 on: June 02, 2006, 12:55 AM »
Stodgy - I bow to your superior knowledge mate, I didn't even know about the change in seattube angle... I only ever noticed the fatty back ends as a difference in the later models   :-[
Brian, I'm liking the flat black   8)
Offline Stace
« Reply #17 on: June 02, 2006, 07:36 AM »
Stodgy
Where did you get the parts list like that?  :coolsmiley:
Stace
Offline Stodgy
    • RADBMX Shop
« Reply #18 on: June 02, 2006, 05:14 PM »
Sweet sticker set Brian - liking that a lot! Should look rad (but you're gonna loose the script 'Condor' sticker on a black frame (mind you - it could look quite cool as it would be shiny and the frame matt black).
I know it's not correct, but I would go for a white or a light blue frame to make the most of those stickers, it would look fabulous.
Rob - Sorry mate I wasn't trying to be too anal, just did a load of research when I built mine...
Stace - For full specs on most bikes, try this link: http://www.airfreetires.com/specs/
Offline BrianP
« Reply #19 on: June 13, 2006, 08:33 PM »
ok, update time...
just finished stripping the condor frame and D130 forks. jeez the inspector burns when it spits!
hoping to get a lick of paint on it this weekend.
Bp.
Offline Stodgy
    • RADBMX Shop
Re: hoffman condor - colour advice (no longer) needed - pics added
« Reply #20 on: June 13, 2006, 09:07 PM »
Ooooo - looking good! How long is that steerer tube?!
Have you decided on a colour?
Offline BrianP
« Reply #21 on: June 13, 2006, 10:24 PM »
is a bit, ain't it?
steerer tube is a good 180mm (7 inches) and the headtube is a more regular 100mm (4 inches).
gonna be a lot of tube sticking out the top of the stem b4 i cut it...
the top of the steerer is threaded too, like the old 1" forks. is this to take the big top cap hoffman used on their completes?
colourwise: flat black, definitely, but i'm not sure how the (mainly blue) decals will look with the orange scheme i'm thinking of...
Bp.
Offline BrianP
« Reply #22 on: June 25, 2006, 09:51 PM »
ok, time for a quick update.
pics taken about half an hour ago, after i finished stickering it up. jeez i can't wait to get this thing built and take it out...
hopefully have it built during or b4 next weekend.
later guys...
ps - dave, turned out i had the fork stickers, just found them in my sticker stash, but can i please take the silver rub-on's off ur hands anyway? cheers buddy,
Bp.
Offline Stodgy
    • RADBMX Shop
Looking sweet Brian!
Offline BrianP
finished - dunno if i like the colour scheme tho.
comments welcome.
Bp.
