dyeing a seat
<< < (2/2)
BENDYCAT ELEVENTEEN:
up to you if you want to try it ?
can you loose the seat if it doesn't work ?
oldskooldayz:
I could buy a seat from pork chop but easier to buy of a member who may need some dosh but I may fo that route
As for the wheel that turned out well sweet  :daumenhoch:
I only paid 14 quid for the seat an it's only a copy thing so yep can loose it if it mucks up
Thanks for the replies peeps  :daumenhoch:
Threaders:
Bear in mind, if you sit on it, the dye will rub off on your pants, and you will end up with yellow showing back through on the seat.  ;)
oldskooldayz:
--- Quote from: Threaders on October 18, 2011, 05:37 PM ---Bear in mind, if you sit on it, the dye will rub off on your pants, and you will end up with yellow showing back through on the seat.  ;)
--- End quote ---
and a blue bum  :LolLolLolLol:  :daumenhoch:
rick1970:
Or stick one of those blue checker cover thingies on it till something pops up  :D
Navigation
[0] Message Index
[*] Previous page
Go to full version
