3/8 inch x 24 tpi axle nuts needed for freecoaster hub.
brettypeeps:
--- Quote from: Mr Dee on October 26, 2011, 01:37 PM ---well the nuts arrived from John. thank you but its no dice... looks like this axle is some weird threads.. bloody Germans and their khe freecoasters.... well i guess it looks like im buying a new wheel unless anyone has any idea how ill can get a nut to fit?
--- End quote ---
If it is german it should be an M10 nut? the have been metric threads for 60 years :daumenhoch:
Mr Dee:
ah a M10? i guess this means a trip to the local b & q or an engineering place...
still I wonder what sort of market there is for a well used Peregrine HP-48 chrome rim?
brettypeeps:
Nigelb might be interested in it???
john4130:
thought they would have fitted, every freecoaster i,ve ever had was a 24tpi. try the m10 nut to see if that works. should be quite easy to get hold of. the nuts i sent will fit a front skyway wheel too.
john4130:
you could always try halfords too, i,ve had a 10mm axle from there before that used a different thread from the normal 26tpi. take the axle with you and ask to see if they can find any that fit.
Navigation
[0] Message Index
[*] Previous page
Go to full version
