Redline Prolines question....
<< < (2/2)
mattfx81:
James I still have the 20mm sealed bearings you gave me if you need them as I never got round to fitting that DB crank.
brummie:
--- Quote from: VOIVOD on November 04, 2011, 08:24 AM --- :) Measure first `cos I fitted a new bb to a bike last week and the Prolines (from 1999) had a 20mm spindle.Other (later)Prolines I`ve owned were 19mm.
--- End quote ---
x2
have had 2 sets of prolines, 1 with 19mm and 1 with 20mm
WINI:
Thanks guys, I'll have a measure up before I do anything.  Are both 19mm and 20mm versions easy enough to get hold of or is one scarce (the one I will need...)
HEYWOOD BMX:
--- Quote from: WINI on November 04, 2011, 11:31 AM ---Thanks guys, I'll have a measure up before I do anything.  Are both 19mm and 20mm versions easy enough to get hold of or is one scarce (the one I will need...)
--- End quote ---
 19MM can be got anywhere cheaply.20MM can be harder and more expensive.Drop MATTFX81 a PM,he may have one available :daumenhoch:
Spen69:
Yep, watch it as I've had a 19mm set and a 20mm set as well :shocked:
Navigation
[0] Message Index
[*] Previous page
Go to full version
