976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 05:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crank tools - Which one do I need
Author Topic: Crank tools - Which one do I need  (Read 2462 times)
stuartD
« on: November 16, 2011, 10:14 AM »
I'm tyring to remove the crank arms from a new school eastern bike so that I can get at the BB. Howver there are no pinch bolts on the crank arms , just the one that screws into the spindle. I know I need a crank removal tool but which one . I believe the cran spindle is one of the mutli spline variety and not an 8 spline .
Any help would be appreciated.
Stuart
Re: Crank tools - Which one do I need
« Reply #1 on: November 16, 2011, 10:27 AM »
Stop ....................... Hammer time  :daumenhoch:
Offline Peter J
  • I have issues
« Reply #2 on: November 16, 2011, 10:30 AM »
This is a bit of a "rough" way to do it as there's a chance you could bugger your crank bolt threads up but if your just throwing them away then its ok"ish" to do it this way
A better way is:
Or this:
http://www.profileracing.com/ht_crank_install.php
And here's the tool:
http://www.tractionkitesuk.com/profile-racefreestyle-crank-arm-installation-tool-p-951.html?utm_source=GoogleBase1&utm_medium=BaseFeed1&utm_campaign=products
stuartD
« Reply #3 on: November 16, 2011, 10:54 AM »
Thanks ,
I'd normally bash the bollocks out of it with a hammer but will purchase the correct tool this time..
Offline Peter J
  • I have issues
« Reply #4 on: November 16, 2011, 10:58 AM »
Slap a good dollop of WD-40 on it use the socket extention method first
It might work and it will save you a few quid  :daumenhoch:
I'm a tight arse Yorkshire man so owt to save a few qiud  :coolsmiley:
« Reply #5 on: November 16, 2011, 11:33 AM »
I've got a tight arse and will do anything for a few qiud
 :shocked: :shocked: :shocked: :shocked: :shocked: :2funny:
Offline Peter J
  • I have issues
« Reply #6 on: November 16, 2011, 11:43 AM »
 :coolsmiley:
Time are hard and friends are few  :daumenhoch:
I'm a poor single parent  :'( with a penchant for N.O.S  :smitten:
Offline john4130
« Reply #7 on: November 16, 2011, 05:07 PM »
remove one crank bolt then tighten the bolt on the other side first, this will help get the spindle moving first if you don't have the correct tool.
HEYWOOD BMX
« Reply #8 on: November 16, 2011, 05:33 PM »
 :) If the arms are threaded inside try these:
http://www.chainreactioncycles.com/Models.aspx'modelID=34314
« Last Edit: November 17, 2011, 12:25 PM by VOIVOD »
Offline Betty
« Reply #9 on: November 16, 2011, 10:12 PM »
2 minutes turkish...
stuartD
« Reply #10 on: November 17, 2011, 05:03 PM »
I went with the "Socket Extension" method and simple and straight forward it was too !  :)
