976295 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 11:56 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing a freewheel without the proper tool
Author Topic: Removing a freewheel without the proper tool  (Read 2688 times)
Rodgy1970
« on: November 22, 2011, 08:40 PM »
Tried two tacks so I could put it in the vice and take it off but this didn't work.
Full on attack with the grinder, then combination of hammer and chisel and vice and off it came.
Re: Removing a freewheel without the proper tool
« Reply #1 on: November 22, 2011, 08:52 PM »
bloody hell, a hammer and screwdriver has always done the job for me, that must've really been on there
Offline Peter J
  • I have issues
« Reply #2 on: November 22, 2011, 08:56 PM »
:shocked:
Never had one stick on that bad  ???
Did you damage the hub at all ?
Love your determination  :daumenhoch:
« Reply #3 on: November 22, 2011, 09:00 PM »
Shit dude you really went at that!  ;D
Offline Gnarlyscoots
  • BANNED
« Reply #4 on: November 22, 2011, 09:01 PM »
dib dobs depending if its a 14T or 16T or 0T  :2funny:  :2funny:  :2funny:
BANNED
« Reply #5 on: November 22, 2011, 09:03 PM »
love a good trashing session  :D
« Reply #6 on: November 22, 2011, 09:10 PM »
I have done a couple that way and the satisfaction when it all comes off is wonderful
top job  :daumenhoch:
rad_pitt
« Reply #7 on: November 22, 2011, 09:46 PM »
 >:D >:D >:D
Offline john4130
« Reply #8 on: November 22, 2011, 11:27 PM »
i always used a hammer and chisel until one got me beat, got a bit of 1/2" square bar and cut it to fit into the grooves on the freewheel. drilled a hole in the centre of it so i could bolt through the hole for the axle then clamped the square bar in the vice and just unscrew the wheel. took about 10 seconds to unscew compared to the half hour battering it with a hammer and chisel and ending up with bloody knuckles when you swing and miss.  :tickedoff:
Rodgy1970
« Reply #9 on: November 22, 2011, 11:53 PM »
didn't think it was gonna come off at all so just went for it   >:D
was really pleased when the drift moved and i had managed not to wreck the hub or the rim   :)
sid1972
« Reply #10 on: November 26, 2011, 07:20 PM »
been there mate... :LolLolLolLol:
Welded a metal bar vertically to one I had and smacked feck out of it, that did the job!
cannot beat a knockometer!  :2funny:
« Reply #11 on: November 26, 2011, 07:44 PM »
Just crush the freewheel in a vice and turn the wheel anti clockwise, do about 3 or 4 a month at work
Offline kev-s
« Reply #12 on: November 27, 2011, 10:19 AM »
jesus :shocked: :shocked: :shocked:
no need for that!!
all i do is remove the centre lockring, take off the teeth ring and catch all the bearings and pawls, so ur just left with the freewheel's bare body on the hub which then can be clamped in a vice and just twisted off
that way u can just rebuild the freewheel and you have caused no damage
« Reply #13 on: November 27, 2011, 10:28 AM »
Apologies, I assumed we were at the point where the freewheel is fooked and has no value, my method is used when replacing a shagged ungreased freewheel from a hub, quickly and efficiently.  Or if you can't be arsed stripping the £4 freewheel  :LolLolLolLol:
