976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 20, 2026, 12:30 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  9/16th pedal spindles been rechromes now wont fit !
Author Topic: 9/16th pedal spindles been rechromes now wont fit !  (Read 3996 times)
Offline neil
« on: December 07, 2011, 12:17 AM »
ive had some rechromed but now they wont fit my crank arms any ideas how to sort them out
Re: 9/16th pedal spindles been rechromes now wont fit !
« Reply #1 on: December 07, 2011, 12:20 AM »
Your local bike shop will run a Die down them for you :4_17_5:
ukoldschool
« Reply #2 on: December 07, 2011, 09:12 AM »
as said above, or a more difficult option is to find a time machine, fly back to just before you hand over the spindles to the chromers and put some tape over the threads and make them write on the job sheet not to chrome the threads. But obviously the first answer is a bit easier ;)
deeman
« Reply #3 on: December 07, 2011, 03:56 PM »
I would pprobably sand the chrome off the first couple of threads carefully with some fairly coarse paper, enough to give it a bite,then tighten as normal,the rest of the chrome should tap out? :daumenhoch:
« Reply #4 on: December 07, 2011, 04:33 PM »
I would be wary of that as it will be the chromium plating between the thread pitch causing the problem. Run a Die down them it will take a few seconds :daumenhoch:
Offline neil
« Reply #5 on: December 07, 2011, 04:38 PM »
the problem is getting the dies for them! bike shops only seem to have taps for crank arms, does anyone have some dies i could borrow? :daumenhoch:
« Reply #6 on: December 07, 2011, 05:01 PM »
A dremel with wire brush attachment?
Offline Discostu
  • Two's Company
« Reply #7 on: December 07, 2011, 06:08 PM »
Take them back to the chromers to have the chrome process reversed. They should be able to remove just the chrome on the threaded part! :daumenhoch:
« Reply #8 on: December 14, 2011, 12:24 PM »
file your crank bosses out n araldite them in  :daumenhoch: take care not to get any araldite on your fingers tho as they will remain tacky for some time and make shelling peas a job lasting longer than is necessary. ;)
« Reply #9 on: December 14, 2011, 12:47 PM »
Offline neil
« Reply #10 on: December 14, 2011, 01:45 PM »
all sorted now Steve 69 has bought some dies  :daumenhoch: so if anyone has a similar problem pm steve im sure hell be able to sort em out for yous (for a small fee :daumenhoch:)
Offline 58 delray
« Reply #11 on: December 14, 2011, 06:40 PM »
 :2funny:  :2funny:
Offline neil
« Reply #12 on: December 14, 2011, 11:54 PM »
 :2funny:  :2funny:
wish id thought of that  :LolLolLolLol: wouldve been a nice way to get the finish nice and smooth on me profiles :daumenhoch: :2funny:
Offline oldtired
  • Dirty Old Man
« Reply #13 on: December 15, 2011, 01:16 AM »
 :LolLolLolLol: fookin brill
