976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 11:00 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  tryes dont seem to fit, is this normal ?
Author Topic: tryes dont seem to fit, is this normal ?  (Read 4169 times)
squigly
« on: December 14, 2011, 02:21 PM »
A while ago i bought some White Gusset pimp tyres, can tell you the size off hand  but when fitted to my tuff II's they are about 2mm too large making them slightly egg shaped when the tubes are inflated, the tyres have an almosdt bead like edge that sits against the rim and when i get this located most of the way around there is a section along the rim about 5" long where it just doesnt fit
anyone else experienced anything like this ?
Re: tryes dont seem to fit, is this normal ?
« Reply #1 on: December 14, 2011, 02:23 PM »
It's the tuffs, try them on some proper wheels and I bet they fit fine  :daumenhoch:
« Reply #2 on: December 14, 2011, 03:10 PM »
You will have to partially inflate the tyre,  Centralize them then continue to inflate them.
They should then run sweet as :daumenhoch:
Agreed :daumenhoch:
« Reply #3 on: December 14, 2011, 03:50 PM »
the walls on the old school wheels had tight tires on them - now they are slightly larger tires on some as the wall on the rims are larger thicker on new ones
Offline 58 delray
« Reply #4 on: December 14, 2011, 06:38 PM »
 :daumenhoch:  :daumenhoch:
« Reply #5 on: December 14, 2011, 06:43 PM »
Agreed :daumenhoch:
What are you running on your FST Bretty?? :daumenhoch:
« Reply #6 on: December 14, 2011, 09:55 PM »
Proper old school Comp ST's so don't have the same problem on my tuffs :daumenhoch:
« Reply #7 on: December 14, 2011, 09:57 PM »
I think Rob was having a poke at th Tuffs, not the Gusset Pimps. :daumenhoch:
Offline 58 delray
« Reply #8 on: December 14, 2011, 10:00 PM »
nowt wrong with tuffs you just have to be carefull how you fit the tyre, i run 60-70 lbs in them with no probs  :daumenhoch:
« Reply #9 on: December 14, 2011, 10:10 PM »
Problem is using new tyres on tuffs,  but as said above and partially inflate then seat them no problems on New tyres either :daumenhoch:
Offline 58 delray
« Reply #10 on: December 14, 2011, 10:11 PM »
« Reply #11 on: December 14, 2011, 11:23 PM »
:D
But he's right.
squigly
« Reply #12 on: December 15, 2011, 10:17 AM »
Cheers guys.
