976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 03:45 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  brake pads for white tuff's
Author Topic: brake pads for white tuff's  (Read 1669 times)
Offline mattbloke
« on: January 04, 2012, 02:54 PM »
does anyone know of a white pad, that actually works on tuff wheels??? and if so how do i get some?
 :coolsmiley:
Offline mattbloke
Re: brake pads for white tuff's
« Reply #1 on: January 04, 2012, 08:02 PM »
really? no one??
Offline oldtired
  • Dirty Old Man
« Reply #2 on: January 04, 2012, 08:52 PM »
all the proper skyway pads work fine  , does depend on what brakes your running and how good they are though  :daumenhoch:, if you can find em in white the copy pads work good to they just ware out a bit quicker , also seen some of the acz zpads in white they are quite sticky
« Reply #3 on: January 04, 2012, 09:01 PM »
The clear pads are supposed to be good on mags..... if you can live with the noise. I ran skyway pads on my decade and they wore out pretty quick   :(
deeman
« Reply #4 on: January 04, 2012, 09:12 PM »
Depends what your after.I take it the bike is a rider?If you specifically want white pads,HALT GOOEYS work well apparently.Available on ebay for about £9 a pair.They will have an old skool look with a nu skool feel.Other than that the new clear pads work great on tuffs.some are totally clear,some are clear with coloured inserts.They do tend to squeak once bedded in though,depends if you can put up with that.I used savage pads,about £6 off ebay and they worked great on tuffs.hope this helps! :daumenhoch:
Offline mattbloke
« Reply #5 on: January 05, 2012, 11:43 AM »
cheers for that guys :) they are for my FS1 survivor/rider. i figured for white pads as they should leave less brake marking on white tuffs? or am i deluded? lol
deeman
« Reply #6 on: January 05, 2012, 11:47 AM »
I dont think it really matters bro,white tuffs will mark whatever pads you use!when the brake rub becomes a bit too much of an eysore its easily removed with a light sanding! :daumenhoch:
