976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 08:21 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  seat post won't fit into frame.***now sorted!!**
Author Topic: seat post won't fit into frame.***now sorted!!**  (Read 4202 times)
  • Andy
« on: January 09, 2012, 07:06 PM »
Hi all. I have a hutch pro racer frame, and i recently bought a hutch seatpost. The seatpost will need a re-chrome before final instalation. My problem is that the post will only go approx 1 inch into the seat down tube before it gets stuck fast. I've also tried another unbranded seatpost with exactly the same results. I can only assume that the frame tubing must be slightly bent or crimped?, although it looks fine to the eye. I went to my local chromers today, and they said they could polish the tube down slightly before they re-chrome it to make it fit. Is this the only or best option? Any other suggestions? Thanks
« Last Edit: January 17, 2012, 08:27 PM by dancetothedrummersbeat »
Offline HUTCHMAN
Re: seat post won't fit into frame. Help!
« Reply #1 on: January 09, 2012, 07:44 PM »
are the ends of the seat post straight cut or rolled over?
  • Andy
« Reply #2 on: January 09, 2012, 11:53 PM »
at work at the moment, so cant check, but am 99% sure are straight cut.
« Reply #3 on: January 10, 2012, 12:05 AM »
Have you Tried a bit of Lube in the seat tube on the frame and a cheap seat post in and out a few times???  Keep it rotating and in and out  :daumenhoch:  it should free it up.
« Reply #4 on: January 10, 2012, 12:21 AM »
Get a tub of vaseline.
Or any substitute grease.
Lube the organ well.
And it will proceed with ease.
Superkav
« Reply #5 on: January 14, 2012, 03:28 PM »
If it only goes in an inch poke your finger down the tube and have a feel. You may find you have an unwanted guest in the shape of the last seat post rammed inside it. I hope not or you're in a world of pain. But for Gods sake check it BEFORE you get it rechromed or you'll be throwing all that money down the loo.
skyway67
« Reply #6 on: January 14, 2012, 05:18 PM »
i had exactly the same trouble it was the rusty weld penetration inside the seat tube stopping it from going in  >:(
so i took it to work and honed it out ,the seat post fits great now  :daumenhoch:
heres the frame set up in the milling machine
« Reply #7 on: January 14, 2012, 06:48 PM »
stick the seat post in the freezer,hopefully it will shrink enough to get it in,ive done this on a coupe of occasions
Offline rooski
  • Mons Veneris
« Reply #8 on: January 14, 2012, 07:28 PM »
Get hold of a 7/8" hand reamer,use that :daumenhoch:
Offline bobbbbsy
« Reply #9 on: January 14, 2012, 08:28 PM »
last thing i did was clean inside the tube well then hold the frame over the gas hob for 2 mins then carefully use a cold used seapost and a rubber mallet to lever and gradually drive down! i am a complete cowboy though! :2gunsfiring_v1:
  • Andy
« Reply #10 on: January 14, 2012, 11:33 PM »
Thanks for all the suggestions so far folks. It doesnt look as though there's another seatpost stuck in there. I've tried wd40, grease & vaseline but with no luck. Also tried putting the post in the freezer & holding the frame above the hob with no luck  :(. It looks as though i'll either have to get the post polished down before i get it rechromed, or use a hand reamer. I've had a look for a reamer and they seem a bit expensive for what (i hope) is a one off job. Does anyone have one that I could borrow? I would have course cover any postage costs both ways. Hoping someone can help. Failing this, are there any more suggestions? Thanks all. Andy
Offline Darren KAP
« Reply #11 on: January 15, 2012, 12:02 AM »
        :LolLolLolLol: dirty fooker  :LolLolLolLol:      try a big hammer  :daumenhoch:   ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, no i'm joking  :LolLolLolLol:
YGT
« Reply #12 on: January 15, 2012, 10:57 AM »
On one frame I had, I took a normal electric hand drill and put on the largest drill bit I could find (16 or 18mm) and covered the drill bit with sandpaper and electrical tape .... gave it a quick internal sanding and the post went in after that .....
Offline bobbbbsy
« Reply #13 on: January 15, 2012, 12:04 PM »
and i thought i was a tool jockey.. but hey if it worked. hats off to you ! :police:
dude. are you being dead careful or are you letting the dragon come out a little ? is it a top frame?
re- read. hutch. nuff said !
« Last Edit: January 15, 2012, 12:42 PM by bobbbbsy »
  • Andy
« Reply #14 on: January 15, 2012, 03:50 PM »
No i'm not veing gentle with it. Tried to give it a bit of wellie, but it's not working. I'll try the drill and sandpaper method. Thanks
Offline rick1970
« Reply #15 on: January 15, 2012, 05:49 PM »
Hi mate ive had this problem , so i rolled up several sheets of sandpaper of different grades and work away starting with the coarse of course takes patience tho and then turn frame over to empty debris then  lube wd40 then wipe stuffing a rag down , then lube again worked for me  :daumenhoch:
  • Andy
Re: seat post won't fit into frame.***now sorted!!**
« Reply #16 on: January 17, 2012, 08:33 PM »
Thanks for all the suggestions people. Rick, I tried the sandpaper trick & it worked. Took me about 30 minutes of sanding though & now I have hands like a navvy! Made up that it's sorted though.
Offline rick1970
« Reply #17 on: January 17, 2012, 08:39 PM »
Good lad  :daumenhoch: looking forward to seeing this and if its as nice as your fox i deffo cant wait !!
  • Andy
« Reply #18 on: January 17, 2012, 08:59 PM »
Thanks Rick. This one could take some time due to the cost & availability of parts. Been at this one for over a year, and can't see it being done this year. My current main build is a peugeot black lion which should be done for MK. I've also just dibbed the falcon pro race flyer f&f in the for sale section. This will be painted blue & badged up as a kappa (as to me the race flyer frame looks exactly the same). It will be a replica of my only bmx from BITD as shown below  :)
« Reply #19 on: January 19, 2012, 12:09 AM »
Ha! ^^^ nice one
