976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 05:20 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  BB Clicking
Author Topic: BB Clicking  (Read 2320 times)
snooze
BB Clicking
« on: January 18, 2012, 03:04 PM »
Hi, My cranks are making  a clicking sound every now and then, could anyone here tell me what it is and how to fix it? I'm a bit concerned that it may fall off or break while I'm riding.
 Thanks
snav69
Re: BB Clicking
« Reply #1 on: January 18, 2012, 03:08 PM »
It's either too tight or there's a bearing or 2 with flat spots  :daumenhoch:
 :coolsmiley:
xGoose
Re: BB Clicking
« Reply #2 on: January 18, 2012, 03:17 PM »
Could also be the splines on your cranks if youre running 2 or 3 piece.
Offline Julian347
Re: BB Clicking
« Reply #3 on: January 18, 2012, 03:19 PM »
I thought my BB was clicking. New bearings, etc, etc, etc. It still kept doing it.  >:(
Turned out my rear sprocket was fooked.
snooze
Re: BB Clicking
« Reply #4 on: January 18, 2012, 04:47 PM »
I have Snafu Mayweathers 48 Spline I think, brand new BB New Cranks, been riding it about a year or so....
Re: BB Clicking
« Reply #5 on: January 18, 2012, 05:05 PM »
Strip, clean, regrease and refit  :daumenhoch:
Offline jimwise68
Re: BB Clicking
« Reply #6 on: January 18, 2012, 05:10 PM »
You sure it's the crank and not one of the pedals?
Re: BB Clicking
« Reply #7 on: January 18, 2012, 05:14 PM »
you sure its not your knees ?  ???
Re: BB Clicking
« Reply #8 on: January 18, 2012, 07:29 PM »
put ear plugs in and the noise will instantly disappear  :daumenhoch:
happy to help  ;)
next  :angel:
Re: BB Clicking
« Reply #9 on: January 18, 2012, 07:38 PM »
did you shorten the chain? maybe a tight link?
Offline Discostu
  • Two's Company
Re: BB Clicking
« Reply #10 on: January 18, 2012, 07:44 PM »
Does it have the correct spacer between the cartridge bearings. If it isn't the right width the pre load from the crank arms against the side of the cartridge bearings click after a while. I would remove the cranks and the spindle and look at the sleeve to see if it butts up against both cartridge bearings. If there is a gap between the sleeve and the bearing you will need to ether fit washers or a longer sleeve.  This can be a problem when swapping cranks from one bike frame to another. Suddenly a perfectly good set of cranks from your old ride start to click in your new ride. I hope this helps. Cheers stu :daumenhoch:
snooze
Re: BB Clicking
« Reply #11 on: January 18, 2012, 09:24 PM »
Ah yes I did shorten the chain but as one member suggested it could also be my knees.......
STU Thanks for your advice I'll give it a go
pickle thanks
Offline oldschoolib
Re: BB Clicking
« Reply #12 on: January 21, 2012, 10:01 AM »
no need for me to ask the question been answered for me  :daumenhoch:
Re: BB Clicking
« Reply #13 on: January 21, 2012, 10:09 AM »
def worth checking this - I thought I had a crank clicking problem and inspector bubbs found out it was just the pedals that needed a bit of grease  :daumenhoch:
