976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 02:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tech engineer question
Author Topic: Tech engineer question  (Read 5231 times)
Offline Gary72
« on: January 24, 2012, 08:56 PM »
I should probably just ask Peterj but would get confused by the answer :-[
Why is it that when you tighten some bolts ie stem bolts that they make that creaking/screeching sound?
Is it friction between bolt and stem? The metal stretching? Am I just been to heavy handed?
Doesn't seem to do it with all bolts, I've heard it from stem, seat clamps etc.
Re: Tech engineer question
« Reply #1 on: January 24, 2012, 09:01 PM »
Could be the types of metal, ie: steal nuts on alloy stems and clamps?
« Reply #2 on: January 24, 2012, 09:02 PM »
Screeching sound ?......Friction ?..... Stretching ?.....Yup Peter J's you man for this  :daumenhoch:
« Reply #3 on: January 24, 2012, 09:04 PM »
It will be friction between the stem wedge & the inside of the forks as you tighten  :daumenhoch:
Offline superbikedan
« Reply #4 on: January 24, 2012, 09:06 PM »
add grease :daumenhoch:
Offline rooski
  • Mons Veneris
« Reply #5 on: January 24, 2012, 09:10 PM »
Its because theres no lubricant between the 2 parts,they are binding on each other,get some copper slip or grease on the threads and under the bolt head :daumenhoch:
Long bolts are worse as they twist slightly under load, then slip,causing the squeaking noise,some times you even get a spark :D
Offline popedante
« Reply #6 on: January 24, 2012, 09:14 PM »
 fook all to do with the bolts , probably your wrist creaking    ;D
« Reply #7 on: January 24, 2012, 09:17 PM »
overtightening  :shocked:
the bars crimping  :-\
the seatclamp hairline fracturing  ???
 :D
Offline Peter J
  • I have issues
« Reply #8 on: January 24, 2012, 09:19 PM »
Not Friction as this is a different force, friction is caused when two surfaces are "pulled" across each other
I think you are describing stiction the frictional force to be overcome to set one object in motion when it is in contact with another
Basically you apply force to one part and at a particular point the (kinetic) energy stored in the material “gives” and moves rather than dispersing the energy into heat (friction) to creek you hear is the energy changing into sound (stiction).
Stiction is within the group of forces under the friction family.
A good example of stiction is when you tighten the wheel nuts up on your car and you get that creek as you finish tightening them up.
I can also give a long winded answer  ???
dan-dare
« Reply #9 on: January 24, 2012, 09:21 PM »
 ;D ;D ;D
« Reply #10 on: January 24, 2012, 09:21 PM »
so is the answer,  add grease :LolLolLolLol:
Offline Peter J
  • I have issues
« Reply #11 on: January 24, 2012, 09:23 PM »
 :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny: :2funny:
« Reply #12 on: January 24, 2012, 09:24 PM »
Spit on it
Offline Gary72
« Reply #13 on: January 24, 2012, 09:28 PM »
Thanks, Car wheel nut sound is the one :daumenhoch:
monkian
« Reply #14 on: January 25, 2012, 09:24 AM »
I'm so hot for you right now :LolLolLolLol: :LolLolLolLol:
Offline Peter J
  • I have issues
« Reply #15 on: January 25, 2012, 09:31 AM »
Do I make you moist  :coolsmiley:
monkian
« Reply #16 on: January 25, 2012, 09:57 AM »
Ooooo Can I ping your braces? ;D ;)
Offline Peter J
  • I have issues
« Reply #17 on: January 25, 2012, 10:15 AM »
Offline Gary72
« Reply #18 on: January 25, 2012, 07:23 PM »
Typical Rad thread, No more than 15 replies and it drops to gutter level ;)
