976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 04:49 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Anybody out there who can retap theads?
Author Topic: Anybody out there who can retap theads?  (Read 1945 times)
Superkav
« on: February 15, 2012, 10:33 PM »
I've got a Hutch spindle with a bad thread that has just knackered the new button screw I tried to put in it. the other pedal was fine so I know the screws are good.
Anybody? I don't have a local metalworks that will do such a small job (not that 've found so far anyway)
Supes
1mancity2
Re: Anybody out there who can retap theads?
« Reply #1 on: February 16, 2012, 09:48 AM »
Just buy a tap and do it yourself.
Superkav
« Reply #2 on: February 16, 2012, 04:53 PM »
Does it need to be a certain size tap? I should probably google it before I typed this :)
« Reply #3 on: February 16, 2012, 05:24 PM »
At a guess I would say UNC thread possibly 7/16th  ;) But I will stand correcting  ::)
Offline HUTCHMAN
« Reply #4 on: February 16, 2012, 07:29 PM »
i take it by using a button head screw your talking about the other end from the crank? 7/16 is .4375" ,just under 1/2 inch,prob more like 3/16(.1875,just over 4.75mm) but Animal is right,most likely UNC,or maybe UNF depending on thread pitch.
mark 2
« Reply #5 on: February 16, 2012, 08:32 PM »
Would it need making bigger and a sleeve putting in? That could be a bugger to get the correct one. Or can you get blank ones to tap?
skyway67
« Reply #6 on: February 17, 2012, 09:33 PM »
if you get stuck i'll sort it for you  :Great_Britain:  :daumenhoch:
