976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 02:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Yellowing trick top seat
Author Topic: Yellowing trick top seat  (Read 1885 times)
« on: February 20, 2012, 09:29 PM »
Does anyone know if yellowing on the white padding on a trick top type seat can be removed/cleaned?  :-\
Re: Yellowing trick top seat
« Reply #1 on: February 20, 2012, 10:41 PM »
put up a pic - some cleaners can but you need to check first - so lets see what we are looking at first
« Reply #2 on: February 20, 2012, 10:44 PM »
Its this one:
http://www.ebay.co.uk/itm/Old-school-BMX-Seat-/130650330718?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item1e6b5dd65e
I know its petty cheap but if i cant get it clean its useless to me  :(
« Reply #3 on: February 20, 2012, 11:01 PM »
 ??? :shocked: sun fading  >:(
it's hard - i had a Kashi seat like that for Adam to do - bleach didn't work at all - in the end had to dye it
it seems to go through the material and turn it yellow - shop window stock
if it was all one colour you could dye it but as it's two then your only choice is orange on orange  :-[
hope this helps make your mind up - if you want a good one then i would pass on this one
cheers B  ;)
« Reply #4 on: February 20, 2012, 11:06 PM »
Cheers Bendy that confirms what i thought.  :daumenhoch:
I had already passed on it once but when it got relisted it was rubbing my nose in it.  ;D
I have read a few guys over on the museum have had good results leaving stuff out in direct sunlight for a few weeks but i think i would be collecting my pension before i saw any change here in sunny Manchester  ;)
« Reply #5 on: February 20, 2012, 11:56 PM »
yer we don't get blistering heat too many times here with the sun - if we do we are mostly working inside  ::) ;D
i would wait for the next one to turn up instead of loose money trying to sort it and nothing going well  :-[
you will find one it's just a matter of when  ;)
Offline bobbbbsy
« Reply #6 on: February 21, 2012, 12:01 AM »
you only looking for orange ?
« Reply #7 on: February 21, 2012, 12:03 AM »
Yeah got a bit of a odd idea for a build and looking for orange stuff  ;)
