976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 06:54 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Is this chain on backwards ?
Author Topic: Is this chain on backwards ?  (Read 3127 times)
Offline Peter J
  • I have issues
« on: March 05, 2012, 01:43 PM »
Sorry for the crappy phone piccy  :-\
But is this on the right way round  ???
Offline Betty
Re: Is this chain on backwards ?
« Reply #1 on: March 05, 2012, 01:51 PM »
It's right Peter...  :daumenhoch:
2 minutes turkish...
« Reply #2 on: March 05, 2012, 01:56 PM »
Yep.
flat side to the outside, links facing backwards on the lower run (grind resistant they say).
Offline Peter J
  • I have issues
« Reply #3 on: March 05, 2012, 02:02 PM »
Cheers Bud,
So there's another reason why it sounds like a bag of spanners in a washing machine  :2funny:
Offline Peter J
  • I have issues
« Reply #4 on: March 05, 2012, 02:08 PM »
Sorted  :daumenhoch:
Chain alignment  :coolsmiley:
« Reply #5 on: March 05, 2012, 02:26 PM »
Soak a paper towel in WD or GT85 and run it along the chain every once in a while, keeps it clean and adds a hint of lube. All you need to do  :daumenhoch:
Offline Peter J
  • I have issues
« Reply #6 on: March 05, 2012, 02:35 PM »
Cheers Bud  :daumenhoch:
I've been slapping red Teflon grease everywhere this morning...........  :coolsmiley: the bikes hardly been used so I've stripped and cleaned it over the weekend I had the chain soaking in WD40 and gave it a rub over with a nylon brush as well  :daumenhoch:
Think the cranks been over tightened or something because the bearings are not the smoothest also I think the front sprocket is a bit thin there's a decent gap when the teeth engage the chain links
I've got a new sprocket and cranks coming soon so I can have a good fiddle then
I can highly recommend the Red Teflon Grease (TF2 Lubricant) bloody good stuff   :daumenhoch:
I can slide a Heinz baked bean tin up my chocolate starfish now and it doesn’t even bring a tear to me eye  :daumenhoch:
motomagII
« Reply #7 on: March 05, 2012, 02:36 PM »
this works and also make sure they arent too tight and they are aligned right .i have had some really noisy half link chains for some reason or another usually too tight or misaligned a tad
« Reply #8 on: March 05, 2012, 02:40 PM »
Some of the Shadow halflinks were rattly old things.
Peter - have a look inside your BB - is the spacer tube in there? That's the main reason for BB bearings fcuking up, spacer missing. You tighten the crank up and crush the inner races toward each other.
If that's all ok though, you can pop the bearings out, pick out the seals with summat very small and pointy. Clean & soak them in petrol or similar and then repack with your nice red grease and snap the seals back in. 9 times out of 10 the bearings will come right back to life.
Offline Peter J
  • I have issues
« Reply #9 on: March 05, 2012, 02:43 PM »
Yep checked the spacer was there when I cleaned/regreased everything  :daumenhoch:
I've only "nipped" the crank arms up and used the little caphead screw to tighten the crank arms up
Do the bearings come out that easy  ??? I thought it would be a hammer and drift job  ???
Offline Dannywhac
  • return of the whac
« Reply #10 on: March 05, 2012, 02:45 PM »
You should have to tw@t bearings out - if they're loose then = trouble :)
« Reply #11 on: March 05, 2012, 03:18 PM »
They are a press fit.
Without insulting your intelligence, that means they are lightly walloped out or in.
Interference fit would require a bearing press or significantly more aggressive hammering - think oldschool headset & BB cups.
They'll only need a light tap with a hammer and a nice weighty drift of some sort.
Offline Betty
« Reply #12 on: March 05, 2012, 03:42 PM »
My half link rattles like fook, the noise of the cassette hub drowns it out once on the move though...  >:D
Offline Peter J
  • I have issues
« Reply #13 on: March 05, 2012, 03:44 PM »
 :2funny: :2funny: :2funny: :2funny: :2funny: :2funny:
Mine sounds the same so I must have set it up right  :daumenhoch:
I'd even put an inclinometer on it to check......you can tell its not british engineered  :Great_Britain:
« Reply #14 on: March 05, 2012, 07:51 PM »
just a thought ? it's not hitting the frame is it ?
Offline rooski
  • Mons Veneris
« Reply #15 on: March 05, 2012, 08:09 PM »
Half link chains are generally noisier than standard chains,avoid if possible :daumenhoch:
mileyboy
« Reply #16 on: March 06, 2012, 01:38 PM »
Offline Peter J
  • I have issues
« Reply #17 on: March 06, 2012, 02:32 PM »
in case you were wondering :D
http://en.wikipedia.org/wiki/Inclinometer
LOL  :2funny:
Sorry when I did a proper days work for a living I was a sado engineer who liked his toys and high end tecky solutions....will go back to been a "salesman" as my Mrs calls me  :tickedoff:
Offline Taipan
« Reply #18 on: March 06, 2012, 03:03 PM »
No but It looks like the bike is the wrong way around? :D
« Reply #19 on: March 06, 2012, 06:15 PM »
Not sure about the bike or chain being backwards but the rider is definitely backwards....... Some would say he was "special". He is from Derbyshire though and they're all famous for webbed fingers and toes and love shoving stuff up  their ringo stars. Wierd really....
