976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 05:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Seat lettering removal?
Author Topic: Seat lettering removal?  (Read 6317 times)
Torker pro-x
« on: March 08, 2012, 09:47 AM »
Best way to remove the gold print off a seat without scratching the plastic? Cheers guys Im guessing some sort of paint/varnish remover??  :daumenhoch:
Offline Munnyella
Re: Seat lettering removal?
« Reply #1 on: March 08, 2012, 10:13 AM »
Try a good, strong adhesive tape, stick it on, give it a good rub/burnish, peel away and it may come off, it did when I removed some patchy printed lightning bolts anyway, don't leave it too long, otherwise you'll end up using spirit of some kind to remove the sticky stuff, which is what you want to avoid.
MM
« Reply #2 on: March 08, 2012, 10:34 AM »
Markys method is best but Cellulose thinners will do it ... BUT try it under the seat first to see what it does  :daumenhoch:
i.e. it might melt the plastic or take the finish off with the lettering  :buck2:
« Last Edit: March 08, 2012, 11:03 AM by ED209º »
Torker pro-x
« Reply #3 on: March 08, 2012, 11:01 AM »
Ok thanks for the replys  :daumenhoch:
motomagII
« Reply #4 on: March 08, 2012, 12:01 PM »
also zippo ligther fluid dissolved adhesive so soak the lettering in theis leave for few mins do couple times till you can get finger nail on edge and lift it tad pour bit more lighter fluid into it and leave for 30 seconds or so and pull hey presto they eppl off nicely.
ps :del showed me this so it aint my idea but it works a treat on any sticker ive removed so far
« Reply #5 on: March 08, 2012, 06:50 PM »
bleach works very well  ;)
Offline kuwahero
    • Western Titans
« Reply #6 on: March 08, 2012, 06:54 PM »
Nail Varnish Remover :daumenhoch:
« Reply #7 on: March 08, 2012, 07:14 PM »
but don't do it while your nail are wet, or you will smudge them  ::)
« Reply #8 on: March 08, 2012, 07:20 PM »
Just out of interest.....why would you want to remove the gold lettering?
rad_pitt
« Reply #9 on: March 08, 2012, 07:25 PM »
I used strong window cleaner to good effect  :daumenhoch:
« Reply #10 on: March 08, 2012, 07:48 PM »
and what does the window cleaner use ?  ???
deeman
« Reply #11 on: March 08, 2012, 11:31 PM »
was kinda wondering that too Rob! :idiot2:
rad_pitt
« Reply #12 on: March 08, 2012, 11:34 PM »
It could be a used seat with the remnants of the original gold lettering, rubbing that off so that the new re-pop decals look better. The re-pop decals aren't the same exact size, and the original gold lettering makes the seat look messy - that was my reason anyway  :daumenhoch:
« Reply #13 on: March 08, 2012, 11:38 PM »
Petrol and matches always work for me, douse the seat in the petrol and set light to it.  No more letters and I can guarantee it will not scratch the plastic either....  Ok there won't be much left but it will not be scratched  :LolLolLolLol:
« Reply #14 on: March 08, 2012, 11:46 PM »
is that how we make things go away  ???  i think they call that fire starting   ;D
« Reply #15 on: March 09, 2012, 12:01 AM »
I like fire, it makes pretty shadows and the voices in my head get louder and LOUDER AND LOUDER
« Reply #16 on: March 09, 2012, 12:41 AM »
 ;D
Torker pro-x
« Reply #17 on: March 09, 2012, 04:16 PM »
Rad Pitt your exactly right! Top marks  :daumenhoch:
Offline Gary72
« Reply #18 on: March 09, 2012, 10:52 PM »
Stidds
« Reply #19 on: March 10, 2012, 05:42 PM »
