976241 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 07, 2026, 04:07 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Axle Nut Size Please
Author Topic: Axle Nut Size Please  (Read 3586 times)
Offline Macmania
« on: March 09, 2012, 01:18 PM »
Think I am correct in thinking that a standard hub (eg Suzue) takes a 3/8x24T nut ? Can someone just confirm before I purchase the wrong ones please.
I know the old Tuffs are 26T.
Thanks Nath
Wanted: Anything MT Racing
Offline wildon
Re: Axle Nut Size Please
« Reply #1 on: March 09, 2012, 01:21 PM »
isn't it the other way around?  ???
Offline wildon
« Reply #2 on: March 09, 2012, 01:22 PM »
i know my peregrines are 26 and they are made by suzue i think
Offline Macmania
« Reply #3 on: March 09, 2012, 01:32 PM »
Maybe it is the other way round then ?  :-\
Offline john4130
« Reply #5 on: March 09, 2012, 04:54 PM »
i think it was just the front tuff that was 24tpi, and most freecoasters. everything else is usually 26tpi.
Offline Discostu
  • Two's Company
« Reply #6 on: March 09, 2012, 05:42 PM »
Suzue and peregrine are 26 tpi
Alloy hub tuff front wheels are 24tpi
Alloy hub tuff rear wheel is 26tpi
Hope this helps. Stu  :daumenhoch:
Offline Macmania
« Reply #7 on: March 09, 2012, 06:54 PM »
Ok thanks guys  :daumenhoch:
retrochrome
« Reply #8 on: January 31, 2013, 01:59 PM »
Good question this i assume 3/8 UNF ?
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #9 on: January 31, 2013, 02:19 PM »
3/8 is axel width so 10mm in this case.  Old school axels are 3/8 or 10mm
TPI does vary but Stu is spot on with his TPI info - thats how they came out of the shop. You'll only run into problems if they've been rebuilt then it can become a bit of a lottery  :shocked:
« Reply #10 on: January 31, 2013, 02:30 PM »
What are suntour please stu ?
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #11 on: January 31, 2013, 05:07 PM »
Suntour coasters are 24TPI
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #12 on: January 31, 2013, 05:08 PM »
Offline wildon
« Reply #13 on: January 31, 2013, 08:33 PM »
Threaded a 26 gt peg onto my front peregrine yesterday and fooked it up...  :-\
