976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 03:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bearing removal on sealed OPC BB? PICS ADDED
Author Topic: Bearing removal on sealed OPC BB? PICS ADDED  (Read 2702 times)
Offline Gary72
« on: March 10, 2012, 07:53 PM »
Trying to strip down a frame I got today and it has a sealed BB on a OPC.  How do I get the bearing out on the non-drive side? I can use the crank to part push out the drive side bearing not all the way out though.
Is there a speacial tool, Dont fancy taking the grinder to the crank as I think it is a Sugino.
Help needed
Gary
« Last Edit: March 11, 2012, 10:39 PM by Gary72 »
Offline HUTCHMAN
Re: Bearing removal on sealed OPC BB?
« Reply #1 on: March 10, 2012, 08:10 PM »
i've always used the tip of a flat screwdriver and gently tapped out the bearing and cup in one go.
Offline Gary72
« Reply #2 on: March 10, 2012, 08:17 PM »
There is no cup, Think I might need to get some pics.
Offline HUTCHMAN
« Reply #3 on: March 10, 2012, 08:19 PM »
Offline Gary72
« Reply #4 on: March 10, 2012, 08:44 PM »
Wife is out working and taken camera with her. But got bearings out, Managed to get the drive side out completly, Then got non-drive side started. Bearing have a small lip all the way round. Had to put drive side back in abit.
Now run into another problem the threads on the drive side of the crank have worn and cant get the spider nut off. What size is the thread on the crank? Should be able to get a die and re-cut it enough.
Also one of the bearing is a rusty mess so dont think the BB is re-useable :buck2:
Offline Munnyella
« Reply #5 on: March 11, 2012, 04:34 PM »
pics Gaz. most sealed bearings have codes on, so you can get replacements without buying a full BB, although it sounds like something unusual you have there, unless you are shiz at descriptions....
MM
Offline rooski
  • Mons Veneris
« Reply #6 on: March 11, 2012, 06:05 PM »
Sound like the bb could be a PPP,no cups,theres a lip ground into the bearings outer race. ???
« Last Edit: March 11, 2012, 06:12 PM by rooski »
Offline Gary72
« Reply #7 on: March 11, 2012, 06:07 PM »
Sound like the bb could be a PPP,no cups,theres a lip ground onto the bearings outer race. ???
That sounds like them, The rusty bearing is going to have a soak in some de-greaser at work. It only had 1 rubber seal on the outside.
Offline Gary72
« Reply #8 on: March 11, 2012, 08:25 PM »
That looks like them, What make is on the rubber seal of the bearing, Mine is GENBEARCO, 6205 is the bearing code.
Offline rooski
  • Mons Veneris
« Reply #9 on: March 11, 2012, 08:58 PM »
i got the pic off the museum,the writing looks like Genbearco though :-\
Normal 6205 bearings measure 52,25,15mm
 that wouldnt fit into the bb shell(51.50MM),bit tight,but with some ground off,would be a nice fit,hence the lip :daumenhoch:
Get pics up :D
Offline Gary72
« Reply #10 on: March 11, 2012, 10:39 PM »
Here's some pics,  It is a Sugino crank, Not stamped on arms though and no year date. What I thought was worn threads I think is the remains of one of the tophat nuts, You can also see the rest of it in the bearing if you look close at the pics.
Also the tab washer is huge. Might be beyond salvage.
Offline rooski
  • Mons Veneris
Re: Bearing removal on sealed OPC BB? PICS ADDED
« Reply #11 on: March 12, 2012, 05:44 PM »
Yep you have a PPP  bottom bracket there,i had one exactly the same,blue seals the lot,custom bearings so clean up and put back on :daumenhoch:
Not many of these about :daumenhoch:
Offline Gary72
« Reply #12 on: March 12, 2012, 06:24 PM »
Any idea where I might get a new thin top hat nut to replace the destroyed one?
Offline rooski
  • Mons Veneris
« Reply #13 on: March 12, 2012, 06:32 PM »
You will need to have one made i,m afraid :(,or maybe another sealed bb will have the same nut ???
