976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 02:21 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cleaning out Seat tube
Author Topic: Cleaning out Seat tube  (Read 1810 times)
Knoxxy
« on: March 15, 2012, 09:38 AM »
I'm building a Redline cruiser & went to put seat post in.
It sounds horrible & the post is super tight, and scratched when removed.
Sounds like the tube is full of rust.
Any tips for cleaning out the tube before fitting?
Thanks.
Knoxxy.
Offline Dannywhac
  • return of the whac
Re: Cleaning out Seat tube
« Reply #1 on: March 15, 2012, 09:45 AM »
I use a bottle brush you can get in homebrew shops + a squirt of WD-40 to give em a good blast out :)
Also check for weld spatter on the inside of the tube where the seat stays meet the seattube - if there is some get a metal file and give it a going over.
Knoxxy
« Reply #2 on: March 15, 2012, 02:05 PM »
Great tips.
Thank you!
Offline sawzall
« Reply #3 on: March 15, 2012, 08:12 PM »
i use a flexi drive on a drill with a flap wheel :daumenhoch:
Offline Gary72
« Reply #4 on: March 15, 2012, 10:32 PM »
Also check the slit/hole at the top.
Offline oldschoolib
« Reply #5 on: March 15, 2012, 10:54 PM »
sawzall x2
skyway67
« Reply #6 on: March 15, 2012, 11:43 PM »
hi had the same trouble so i honed it out at work
« Reply #7 on: March 16, 2012, 10:06 AM »
If its just rust will the seatpost tube with vinegar. This will clean all the rust off in a couple of hours  ;)
