976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 06:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  hub axle question
Author Topic: hub axle question  (Read 2414 times)
Offline wildon
hub axle question
« on: March 22, 2012, 07:19 PM »
If i wanted to change the rear axle in a Peregrine hub from 26t to 24t can i just use a rear Skyway axle setup or will that just not fit at all?  is this a stupid question  :buck2:
Offline Discostu
  • Two's Company
Re: hub axle question
« Reply #1 on: March 22, 2012, 07:25 PM »
Unsealed then yes. Sealed then no unless it's 59mm from bearing stop to bearing stop.  :daumenhoch:
Offline wildon
« Reply #2 on: March 22, 2012, 07:26 PM »
Nice .. cheers Stu  :daumenhoch:
Offline john4130
« Reply #3 on: March 22, 2012, 08:00 PM »
rear skyways are 26tpi, it's the front thats 24tpi.
Offline wildon
« Reply #4 on: March 22, 2012, 08:06 PM »
i don't think so, pretty sure o/s ones were 24 front and rear and newer ones 26 front and 24 rear  ???  i could be wrong ..
Offline wildon
Offline Discostu
  • Two's Company
« Reply #6 on: March 22, 2012, 09:55 PM »
No he is right. Rear 26 tpi. Front is 24 tpi.  :daumenhoch:
« Last Edit: March 22, 2012, 10:24 PM by discostu »
Offline wildon
« Reply #7 on: March 22, 2012, 09:58 PM »
No that he is right. Rear 26 tpi. Front is 24 tpi.  :daumenhoch:
oh ffs
Offline john4130
« Reply #8 on: March 22, 2012, 10:18 PM »
if you need a 24 tpi axle you can get one from custom riders, no cones or bolts are included tho.
http://www.customriders.com/prodshow.asp?prodid=1603&cat=1&parent=1001&sid=3
