976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 06:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  wheel lacing problem
Author Topic: wheel lacing problem  (Read 3267 times)
Offline bigfatolly
« on: March 24, 2012, 04:15 PM »
acs z rim,acs low flange hub,asahi 194mm spokes,36 hole,laced 3 cross as in stidds guide.
had a go at lacing a wheel today,everything looks ok and i have compared to another wheel visually,all looking ok
however when i started to tighten the nipples at the end of the build i have ended up with(looking on the inside where the inner tube would sit)
2 spokes sat tight in there seat,2 spokes sticking out,2 spokes sat tight in there seat,2 spokes sitting out,  and so on and so on all the way round.
i have screwed all the spokes nearly to there limit in the nipple but not tight
when i spin the wheel it looks fairly true,but obviously i need all the nipples sat tight in there holes and flush.
how do i achieve this?
thanks in advance :daumenhoch:
Re: wheel lacing problem
« Reply #1 on: March 24, 2012, 05:01 PM »
Make sure that all the spokes are crossing correctly i.e. spoke over the 1st two spokes and under the 3rd.  Also make sure that you have the spokes on the left of the hub going to the left side offset spoke holes on the rim.  You can loosen off all of the spokes and then do the same amount of turns on each spoke to ensure you tighten them evenly.
Also look at my spoke calculation thread in the tech and restoration stickies section and see if you definitely have the correct spoke sizes.  I must say I never ever accept that a spoke size is 100% correct UNLESS I have done the calculations myself, trusting what other people say is a short road to trouble.
Offline bigfatolly
« Reply #2 on: March 24, 2012, 05:05 PM »
All the spokes are correct i think i may have tightened them wrongly,will loosen them all and try again,
Will also check the spoke size calculator :daumenhoch:
« Reply #3 on: March 24, 2012, 06:18 PM »
When u hold the wheel by the spindle how does the dish of the wheel look buddy ? It sounds like u r a hole out on the spokes or the spokes r 2 long 2 do 3 cross . Let us know an I will help some more  :daumenhoch:
« Reply #4 on: March 24, 2012, 06:23 PM »
ive had this before, try a 4x pattern it should work
Offline wildon
« Reply #5 on: March 24, 2012, 06:37 PM »
this .. 194's need a 4 cross pattern, 3 cross would be 186/184  :daumenhoch:
Offline bigfatolly
« Reply #6 on: March 24, 2012, 06:41 PM »
checked the spoke calculator and i reckon the spokes are too long as it comes up about 182mm so would need the 184mm spokes.
how do i do a 4 cross pattern?
i mastered the 3 cross pattern lol
« Reply #7 on: March 24, 2012, 06:45 PM »
cross over 3 and under the 4th spoke, its the same principal as a 3x pattern
Offline wildon
« Reply #8 on: March 24, 2012, 06:47 PM »
this is brilliant for a 4 cross pattern  http://bmxmuseum.com/forums/viewtopic.php?id=47611
Offline bigfatolly
« Reply #9 on: March 24, 2012, 06:59 PM »
So you spoke the first set as normal with 3 holes in between each spoke but on the second set of spokes you cross 3 spokes instead of 2 before you tuck under??
Offline wildon
« Reply #10 on: March 24, 2012, 07:00 PM »
yep  :daumenhoch:
Offline bigfatolly
« Reply #11 on: March 24, 2012, 08:48 PM »
Eureka!!!!!!!!!
Just laced it 4 cross .problem solved!!
Cheers guys,feeling quite pleased with myself though it has took from 2 oclock til now to lace one wheel  :LolLolLolLol:
« Reply #12 on: March 24, 2012, 10:28 PM »
 :daumenhoch: top feeling when u sus it bud  ;)
« Reply #13 on: March 24, 2012, 10:30 PM »
Offline rooski
  • Mons Veneris
« Reply #14 on: March 24, 2012, 10:33 PM »
Did my first wheel build this week very pleasing :daumenhoch:,its almost like inventing the wheel :D
motomagII
« Reply #15 on: March 25, 2012, 10:47 AM »
ive had this it was laced wrong even though it looked right diggler relaced it 3 cross same and it was sound when he did it right
