976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 02:32 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  This stuff really works...!
Author Topic: This stuff really works...!  (Read 2505 times)
Offline Devilock
« on: April 01, 2012, 05:55 PM »
As some may remember I had some very stubborn decal adhesive all over my TA & suggestions were offered for its removal.
However, my curiosity resulted in buying this...... Its amazing!!  :shocked: No harm to the chrome frame & did EXACTLY what it says on the tin!
Spray, leave for about 7min then remove adhesive with a spatula type implement. I used a wooden spatula & it left no surface scratches. Nice lemon odour too...!! Im presuming its composition contains lemon juice...?? Im thinking its acidic properties break down the adhesive...??  ???
« Last Edit: April 01, 2012, 06:02 PM by mothwasp »
Offline Betty
Re: This stuff really works...!
« Reply #1 on: April 01, 2012, 11:29 PM »
2 minutes turkish...
Offline Hiro Tonka
« Reply #2 on: April 02, 2012, 10:26 AM »
Cool, thanks for the tip.
lighter fluid is also very good, £1 from the market. I use it alot to remove stickers from record sleeves.
Steven
« Reply #3 on: April 02, 2012, 03:45 PM »
pussy girls blouses pansie boy homs  ::)
i took the mans way of removing the head tube decal juice off my HAWK
THE only tool you'l ever need  :daumenhoch:
« Last Edit: April 02, 2012, 03:46 PM by OrgasmDonor »
Offline Devilock
« Reply #4 on: April 02, 2012, 09:20 PM »
Mamba
« Reply #5 on: April 02, 2012, 09:27 PM »
Must keep  that in mind, I just used some cellulose thinner I happen to have lying around which worked well. Not the stuff to use if you're in a not ventilated room unless you really do like having an argument with oversized Penguins about why freedom of expression can't include .50 cal bullets. :idiot2:
Offline Devilock
« Reply #6 on: April 02, 2012, 09:32 PM »
I prefer acid......!!  :D
Mamba
« Reply #7 on: April 02, 2012, 11:15 PM »
I got a sweatband for my frame, put a few tabs under it and it didn't shift any of the old paint  >:( So much for the power of Acid!!  ::) :crazy2:
