976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 03:42 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  BLEACHING SEATS
Author Topic: BLEACHING SEATS  (Read 1505 times)
Offline PRO THUNDER
  • Wanted. Huffy Pro Thunder bikes and parts.
BLEACHING SEATS
« on: April 18, 2012, 05:29 PM »
I've seen an Odyssey leading edge seat on the bay. The main part of the seat is black but the rear part is grey. I was wondering if you can bleach/dye this rear part so that it goes to white. You can remove this rear part and refit it after.  Can anyone help or has anyone done it before?   :daumenhoch:
Re: BLEACHING SEATS
« Reply #1 on: April 19, 2012, 10:39 AM »
Need to see a picture
but in practice of dying and bleach the slight rules are - if the dye has been put in at the process of making then the dye will run the whole way through - so the bleach will only take out from the top of the surface and a couple of mm in some times - the colour will be zapped out and some times only dull /fade the colour
it just depends on the seat and what it's made of  ???
Offline PRO THUNDER
Re: BLEACHING SEATS
« Reply #2 on: April 19, 2012, 01:45 PM »
Cheers Bendycat
I'll try and get a photo up tonight. The auction is ending tonight, so I'll try.  :daumenhoch:
Offline PRO THUNDER
Re: BLEACHING SEATS
« Reply #3 on: April 19, 2012, 06:46 PM »
Here are some pics of the seat. As I said before , the rear part looks like it unclips from underneath.  :daumenhoch:
Re: BLEACHING SEATS
« Reply #4 on: April 19, 2012, 11:03 PM »
Just looked at the pic's - sorry mate will not bleach white  :-\ :-[
as for dying - it might but it has to be a darker colour and if it doesn't have any nylon in it when it was made it will not take - if it does it might dye ok
it's never easy to tell till it's in yer hand
is the plastic hard or soft / you don't show how it un-clips
if you were to dye it what colour are you looking to go ?
cheers B  ;)
Offline PRO THUNDER
Re: BLEACHING SEATS
« Reply #5 on: April 20, 2012, 01:23 PM »
I was hoping to dye it white :P I'am glad I didn't buy it now. Thanks for the advise B. Stuart :daumenhoch:
