976294
Homebrewhero
June 16, 2026, 05:42 PM
epoch mori headache
Topic: epoch mori headache (Read 3519 times)
markyp
900 Air
epoch mori headache
April 19, 2012, 07:45 PM »
i bought one of those epoch headset from spartacus just for a change but am having trouble fitting it now.its all together except the lock nut wont go on as ive got no room for it,the rest of it sits flush with the top of the steerer.ive got about 1mm slack on both cups so can bang them home but that will at most give me 2mm to thread on the lock nut, any help appreciated before i chuck this fookin patty out of the loft room window
dordymush
Berm Worm
Re: epoch mori headache
April 19, 2012, 07:48 PM »
i had some tange forks there were just the same with one of these head sets.
but fitted it to my GT and fitted normal
markyp
900 Air
April 19, 2012, 07:54 PM »
oh dear maybe they became gt epoch cos thats the ony fookin bike they fit
waza04
Best chuck it out the window mark.
brummie
Team Moderator
My life is Radbmx
April 19, 2012, 07:55 PM »
ben had the same problem with his torker mark
markyp
900 Air
April 19, 2012, 08:00 PM »
maybe will i roll without the bearings,this should cut me enough slack
Gnarlyscoots
Riding with Stabilisers
BANNED
April 19, 2012, 08:03 PM »
Wait 'til I get there Mark before you throw that Patty out the window please. Which window is it coming out of
BANNED
waza04
April 19, 2012, 08:15 PM »
Got a nice GT Pro frame it will fit mark if interested.
markyp
900 Air
April 19, 2012, 08:56 PM »
just found an old museum thread about these headsets,turns out that the bearings are made specifically for either the top or bottom cups so may take the thing apart at the weekend and swap the bearings about,hope this works
HEYWOOD BMX
April 19, 2012, 11:20 PM »
Maybe someone can measure the stack height of these & other OS headsets? Make it a sticky & then it can be used as a reference so peeps know what headset will/won`t work with their F/F.
Devilock
Berm Worm
April 20, 2012, 07:58 AM »
I know what forks are compatible............GHP!!!
markyp
900 Air
Reply #11 on:
April 20, 2012, 04:18 PM »
right,ive just fannied about with it,changed the bearings around and its given me a 1mm extra,just about enough without the lock washer.with the cups smashed home i will just about have enough i think,wouldnt want to ride it tho like that,one jump and the lock nut would be snapped off
GTnumber1
Look Back
Reply #12 on:
April 20, 2012, 04:40 PM »
Buy a GT problem solved
Devilock
Berm Worm
Reply #13 on:
April 20, 2012, 05:18 PM »
Quote from: GTNUMBER1 on April 20, 2012, 04:40 PM
I would!!!
markyp
900 Air
Reply #14 on:
April 20, 2012, 05:25 PM »
got one already so there
750Rush
Reply #15 on:
April 21, 2012, 10:00 PM »
I've got one on my mongoose californian and it fitted perfectly. I knoe it's a silly question, but have you put the bearing in the right way around so they sit flush in the cups?
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
Reply #16 on:
April 21, 2012, 11:00 PM »
epoch mori headache
