Chopping bar width. Easiest & cheapest...
Betty:
Try them before you give them the chop, 28" wide is spot on :daumenhoch:
Hellcat:
--- Quote from: Betty on April 22, 2012, 09:55 PM ---Try them before you give them the chop, 28" wide is spot on :daumenhoch:
--- End quote ---
Ok will do. Guess I have to fit them before hacksawing. :daumenhoch:
Dark Diggler:
Dont cut em bud, you will regret it :daumenhoch:
Hellcat:
--- Quote from: Dark Diggler on April 22, 2012, 10:02 PM ---Dont cut em bud, you will regret it :daumenhoch:
--- End quote ---
Ok. Will def swap & give em a go before cutting. :daumenhoch:
Gary72:
I've used a plumbers pipe cutter from B&Q a few times. Takes abit longer but I think it gives a neater finish. Only problem I've come across is that you have to file the inner part of the tube where the bar end goes.
Navigation
[0] Message Index
[*] Previous page
Go to full version
