14mm axle to fit 10mm forks?
<< < (3/3)
ED209:
--- Quote from: dannywhac on April 26, 2012, 02:39 PM ---That is a point - if the axle wall thickness is 3mm you could get away with it - that'd leave 1mm thickness after shaving.
--- End quote ---
Thats a bit risky tho  ??? you can't be that precise with the ol'grinder - as you pointed out Dan I'd only ever do it on solid axles to be honest.
kev-s:
why not take the forks out to 14mm if there is enough meat on the dropouts?
Hellcat:
There's not. The drop outs are pretty slim.
I'll see if the bike shop can sort out an axle & bearings, if not, just wait for the right cheapish wheel to come along.
TwoBobRob:
I'd be taking the grinder to the forks. It's only 2mm either side.
Stick a photo of the forks up, let's have a look.
Spen69:
--- Quote from: TwoBobRob on April 28, 2012, 07:37 PM ---I'd be taking the grinder to the forks. It's only 2mm either side.
--- End quote ---
^ Yep, what he said ^
Navigation
[0] Message Index
[*] Previous page
Go to full version
