976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 07:20 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What the difference between....
Author Topic: What the difference between....  (Read 1759 times)
« on: April 30, 2012, 12:58 AM »
Ok so what is the difference between a '82 team mongoose and a '82 motomag ?
am i right in one thing, is that the motomag has a hole in the bottom bracket to chain stay tubes
but what the rest ?
cheers B  ???
Re: What the difference between....
« Reply #1 on: April 30, 2012, 09:10 PM »
in yer own sweet time folks  :knuppel2:
« Reply #2 on: April 30, 2012, 09:14 PM »
ones heavy as fook n the other is fookin heavy, only being ever so slightly lighter due to the afore mentioned hole  :daumenhoch:
« Reply #3 on: April 30, 2012, 09:51 PM »
 ::) ;D it's a start  ;D
so apart from being 3 grams lighter any one else have a clue  ;)
« Reply #4 on: April 30, 2012, 09:58 PM »
The Team gooses were candy red or blue!
The motomags were half steel and half cro-moly frames so deffo weighed more! Components were a lot cheaper as well
Team
motomag
« Last Edit: April 30, 2012, 10:03 PM by RATTY »
« Reply #5 on: April 30, 2012, 10:19 PM »
Iirc the team had a flat spot on the rear right brake tube near the rear dropout so the chain didn't rub the tube and the serial number began with 'T'.
Frosty
« Reply #6 on: April 30, 2012, 10:40 PM »
Stidds you recall correctly, check my motomag seat stay for a non flat and the evident chain rub
