976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 02:49 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Will one be enough...?
Author Topic: Will one be enough...?  (Read 1864 times)
Offline Devilock
« on: May 09, 2012, 10:18 AM »
 Tom very kindly sent one Dylon he had spare & I want to dye some grips...will one suffice...?  :-\
Re: Will one be enough...?
« Reply #1 on: May 09, 2012, 10:51 AM »
Easily enough for grips  :daumenhoch:
Offline Devilock
« Reply #2 on: May 09, 2012, 11:20 AM »
Nice one  :)
Stupid question but never used them before- apart from the cellophane, how much of the packaging do I remove before putting in the water..?!!  :-\
rad_pitt
« Reply #3 on: May 09, 2012, 12:39 PM »
You can clip away the lid and pour it in - but it's fiddly. I punctured the tin and chucked the lot in to save the dye getting everywhere  :LolLolLolLol:
« Reply #4 on: May 09, 2012, 03:28 PM »
For some reason they seal the tins so only NASA can get into it  ::)
over the sink - gloves on (rubber not woolen ;D) - you can prise up the edge till there is enough to peel back or you can punture the top in a a V and push in, and then you can shake out - or after the V just drop in the water and stir around
now you haven't said what grips they are ? some dye (just about) and some won't at all  ???
Offline Devilock
« Reply #5 on: May 09, 2012, 05:27 PM »
Well...Im presuming it'll be fine as they're featured in the stickie- red Oakley 2  ;)
