976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 12:10 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Shimano sx stuck in sr one piece - broke my dk multi tool!!!! Any suggestions?
Author Topic: Shimano sx stuck in sr one piece - broke my dk multi tool!!!! Any suggestions?  (Read 1661 times)
NathanRelton
Hi. Skin off knuckles, pedal spanner broken, dk multi tool broken, Allen key rounded. Revving up the angle grinder unless someone has a better idea  >:(
Offline Discostu
  • Two's Company
Just a thought are you undoing it the right way? The non drive side is left hand threaded. And the drive side is right hand threaded.  :daumenhoch:
pkripster
grind the pedal arm off clamp it in something
NathanRelton
Yes.........
Although if I'm honest I've spent ages before trying to take off a pedal when actually I have been making it tighter. The mo fo is tasting the grinder later!
sid1972
what's a DK multi tool  ???  :LolLolLolLol:
heat the fecker up and get an adjustable on the bad boy whilst securing the crank in the vice.  :D
Offline kev-s
lay the crank/bike on it side and spray a load of wd40 in the back of the pedal axle and leave overnight for it to soak in then try and remove it with a proper pedal spanner
http://www.chainreactioncycles.com/Models.aspx'modelID=42806&utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom
