976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 25, 2026, 08:11 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  1" forks into 1 1/8" frame > > the easy way >
Author Topic: 1" forks into 1 1/8" frame > > the easy way >  (Read 3314 times)
David
« on: June 27, 2006, 05:11 PM »
Angle grind off 1" cup complete with headtube ???
The perfect shim :daumenhoch:
Sweet bodge huh? :LolLolLolLol:
motomagII
Re: 1" forks into 1 1/8" frame > > the easy way >
« Reply #1 on: June 27, 2006, 05:38 PM »
not the way i did it but hey if it works
silentpartner
« Reply #2 on: June 27, 2006, 07:43 PM »
why?  :-\
David
« Reply #3 on: June 28, 2006, 10:48 AM »
why?
« Reply #4 on: June 28, 2006, 10:49 AM »
you gotta do what you gotta do.
Offline BrianP
« Reply #5 on: June 28, 2006, 11:44 AM »
is that a sturmey archer 3-speed hub?
Offline Wayne Ryder
« Reply #6 on: June 28, 2006, 12:13 PM »
Rekka did some great adaptor cups for this, I had some Prolite 1"ers and a Hoffman stem to put onto a Schwinn Jay Miron frame.
It sounds easy and convenient, till you've got to find some of the damn things.
Howsabout the reverse? Isn't there a specific set of bearings you can use to put your 1 1/8" forks into an Old School 1" frame?
David
« Reply #7 on: June 28, 2006, 02:43 PM »
Sachs 3-speed with coaster :daumenhoch:
« Reply #8 on: June 28, 2006, 03:51 PM »
the ghetto way of doing it is use two sets of 1" bearings, taken out of their cases (you can fit almost 2 sets in each cup, held in with grease) then use the other parts of the aheadset and clamp on stem
its fairly straightforward to do
Offline BrianP
« Reply #9 on: June 28, 2006, 04:10 PM »
v cool. i bet the 2nd gear works way better than 2nd gear on a sturmey archer hub, a la nuts on crossbar type grifter / chopper gearing... ;)
duncan
« Reply #10 on: June 30, 2006, 01:30 AM »
Have you allowed the frame to rust then clearcoated or oiled over the top?
Or is it one of those rust-look paints?
I read a forum thread just yesterday about achieving a "rust" finish on a bike, whilst ensuring that the rust is halted in its tracks.
It's different.
David
« Reply #11 on: June 30, 2006, 07:37 PM »
Yeah, that's genuine rust.
I spilt oil on the frame trying to lube up that 3-speed - so I lubed up the whole frame.
The sheen's now gone, it look's pretty cool.
I wasn't trying to preserve it.
So what's this technique for halting rust in it's tracks?
