976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 04:13 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  cups
Author Topic: cups  (Read 2436 times)
Danny BMX
cups
« on: June 03, 2012, 12:55 PM »
How do you install the headset cups and bb cups?
Re: cups
« Reply #1 on: June 03, 2012, 12:56 PM »
I generally use a big bit of 4x4 and a big lump hammer  :daumenhoch:
Offline Taipan
Re: cups
« Reply #2 on: June 03, 2012, 01:58 PM »
or a vice :daumenhoch:
Danny BMX
Re: cups
« Reply #3 on: June 03, 2012, 02:00 PM »
It's just been powdercoated so don't want to damage it
Re: cups
« Reply #4 on: June 03, 2012, 02:01 PM »
Do this.
Make sure they are level then wack em in.
Most steel cups are harder than tarzan's feet so they will take a good beating.
Remove any powdercoat that is inside the tubes though!
Or you can gay about with fitting kits.
Do it late at night too - the neighbours will love it.
Danny BMX
Re: cups
« Reply #5 on: June 03, 2012, 02:28 PM »
so i need to scrape the powdercoating out first. I live in a flat so cant be doing it to late
Re: cups
« Reply #6 on: June 03, 2012, 02:32 PM »
Yeh if there is powder inside the headtube it makes the job much harder!
It doesn't exactly fall off either.  Good luck!
Offline bobbbbsy
Re: cups
« Reply #7 on: June 03, 2012, 02:39 PM »
a big g clamp and 2 bits of wood !
Re: cups
« Reply #8 on: June 03, 2012, 02:46 PM »
I'm with the Ruler on this, but here's a little more detail;
You need another pair of hands, especially if you're doing this for the first time, two lumps of 4x2 wood or similar, a drop of oil or grease and a hammer.
Right, headset first;
A good powdercoater won't have done the inside of your headtube but if he has, you MUST clean the area up completely first, then rub a lttle oil or grease areound where the cup is going to sit. Then get your other pair of hands to hold the frame so you can position a cup nice and level ready to be whacked in. The headtube must rest on one of your lumps of wood, then you place the other lump of wood on top of your nicely positioned cup and give it a whack. Don't be surprised if it takes a few goes, or that you're hitting it harder than you think you should.
To summerise, Clean & lube the headtube, set the work up in this order = wood/frame/cup/wood/hammer.  Give it a good lump with your hammer. Good luck!
Now, Bottom Bracket;
Exactly the same as the headset  :)
Enjoy.
Danny BMX
Re: cups
« Reply #9 on: June 03, 2012, 03:21 PM »
Thanks for the help will try put pics up later if i get it done
Re: cups
« Reply #10 on: June 03, 2012, 03:23 PM »
It'll either be piss easy or a royal pain in the arse, you never can tell....
Whereabouts do you live?
Danny BMX
Re: cups
« Reply #11 on: June 03, 2012, 06:25 PM »
Im still trying to get the powdercoating out.
I live in liverpool.
Re: cups
« Reply #12 on: June 03, 2012, 06:42 PM »
As said, a decent powder coaters should've known to blank out the BB shell and head tube.  School boy error on their part.  It's a fair bet they've powdered your BB as well?  If so its a right pain in the arse to get all that out without taking some off the outside  ???
Danny BMX
Re: cups
« Reply #13 on: June 03, 2012, 07:08 PM »
Yeah your right powdered that to i new that should'nt of been done
Re: cups
« Reply #14 on: June 03, 2012, 07:10 PM »
Can you take it back and ask them to sort it or redo the whole thing again?
Danny BMX
Re: cups
« Reply #15 on: June 03, 2012, 07:31 PM »
i had it done in Birkenhead so don't fancy going back
Re: cups
« Reply #16 on: June 03, 2012, 07:50 PM »
That's a job for a dremel or a small drill attachment of some sort. Ballache.
