Installing Grab On foam
Devilock:
Ive soaked the foam but its still stiff. And yes Im attempting it not on the bars!
Ill try including washing up liquid.
Plus one is longer so Ill have to trim it. F*cking stupid things >:(
kungfunky:
Put it in the oven for a good hour, that will REALLY soften it up ;D
Devilock:
--- Quote from: kungfunky on June 04, 2012, 01:27 PM ---Put it in the oven for a good hour, that will REALLY soften it up ;D
--- End quote ---
Do they compliment roasted veg...??!!! ;D
Will it work...? ???
kungfunky:
--- Quote from: Devilock on June 04, 2012, 02:48 PM ---
--- End quote ---
--- End quote ---
:LolLolLolLol: Don't over do the roast though.
I have no idea if it will work, keep the temp low and watch them every second. Sounds a little risky TBH..
deeman:
soak the grips in hot water first Rich,then lube up the foam with washing up liquid or WD40! :daumenhoch:
Navigation
[0] Message Index
[*] Previous page
Go to full version
