976293
Homebrewhero
June 15, 2026, 06:29 AM
what best simulates chrome?
Topic: what best simulates chrome? (Read 2439 times)
Night Rider
June 07, 2012, 12:25 PM »
Got some sugino caps that I want to rescue
Jamroll
Look Back
Re: what best simulates chrome?
June 07, 2012, 12:48 PM »
Machine Polishing em
Night Rider
June 07, 2012, 02:10 PM »
Quote from: Jamroll on June 07, 2012, 12:48 PM
They are plastic, coated with a chrome finish which is now less than perfect I need to recoat them with a paint of some kind. I think machine polishing would melt the plastic, they are beyond that anyhow.
dordymush
Berm Worm
June 07, 2012, 02:12 PM »
i tried the chrome spray on a set of mine that looked ok.
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
June 07, 2012, 02:16 PM »
search you tube - i did see some good chrome spray paints that will do just the job + help how to do right
oldschoolace
Team Moderator
Double Flip Whip
Bodger
June 07, 2012, 02:38 PM »
Modern chrome paints are pretty decent now also
stidds
Site Supporter
My life is Radbmx
Posts: I am a geek!!
June 07, 2012, 03:24 PM »
You can buy rolls of very thin aluminium that can be heated slightly to form shapes, then cut off the excess. I have used it many times.
meticulous
Berm Worm
June 07, 2012, 04:05 PM »
forget the chrome spray, unless you know exactly what you are doing.... the tin foil trick sounds the best option to me....
R.I.P O.M. Far short of the finish line...
stillriding
June 10, 2012, 08:46 PM »
try a model shop for foil they use on scale airplanes you use an iron to fix it
ive used it on a frame
it does look much better then this pic shows
hunterdubber
Site Supporter
Berm Worm
June 11, 2012, 07:16 AM »
Plasti kote do a chrome spray ? anybody tried it
The original Sugino are only coated , thats why they're always worn on relatively lightly used ones
meticulous
Berm Worm
June 11, 2012, 07:33 AM »
to get the correct chrome finish with chrome spray it has to be applied over a very high gloss black finish, i've tried it before and its shite.... but thats part in me being heavy handed and blond!
