976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 06:28 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  what best simulates chrome?
Author Topic: what best simulates chrome?  (Read 2438 times)
Night Rider
« on: June 07, 2012, 12:25 PM »
Got some sugino caps that I want to rescue
Offline Jamroll
Re: what best simulates chrome?
« Reply #1 on: June 07, 2012, 12:48 PM »
Machine Polishing em   ???
Night Rider
« Reply #2 on: June 07, 2012, 02:10 PM »
They are plastic, coated with a chrome finish which is now less than perfect I need to recoat them with a paint of some kind. I think machine polishing would melt the plastic, they are beyond that anyhow.
« Reply #3 on: June 07, 2012, 02:12 PM »
i tried the chrome spray on a set of mine that looked ok.
« Reply #4 on: June 07, 2012, 02:16 PM »
search you tube - i did see some good chrome spray paints that will do just the job + help how to do right  ;)
« Reply #5 on: June 07, 2012, 02:38 PM »
Modern chrome paints are pretty decent now also  :daumenhoch:
« Reply #6 on: June 07, 2012, 03:24 PM »
You can buy rolls of very thin aluminium that can be heated slightly to form shapes, then cut off the excess.  I have used it many times.
« Reply #7 on: June 07, 2012, 04:05 PM »
forget the chrome spray, unless you know exactly what you are doing....  the tin foil trick sounds the best option to me....    :)
stillriding
« Reply #8 on: June 10, 2012, 08:46 PM »
try a model shop for foil they use on scale airplanes you use an iron to fix it
ive used it on a frame
it does look much better then this pic shows  :LolLolLolLol:
« Reply #9 on: June 11, 2012, 07:16 AM »
Plasti kote do a chrome spray ? anybody tried it
The original Sugino are only coated , thats why they're always worn on relatively lightly used ones  :-\
« Reply #10 on: June 11, 2012, 07:33 AM »
to get the correct chrome finish with chrome spray it has to be applied over a very high gloss black finish, i've tried it before and its shite....  but thats part in me being heavy handed and blond!
