976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 25, 2026, 07:52 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How to; Twin pull brakes problem solver.
Author Topic: How to; Twin pull brakes problem solver.  (Read 2438 times)
Offline aditup2004
« on: June 27, 2006, 10:56 PM »
I have suceesfully fitted a Bottom half of a giro cable, upside down, to enable a twin pull brake to be used without a Giro.
#1 You need to cut off the nipples, on the "twin ends", remove the outer cable.
#2 You will need one of these levers, as they have a cable "grip" built in to lever itself;
#3 You will also need 2 of these nipples, normally supplied with a twin pull brake;
#4 offer up the cable to the frame, to establish where it is going sit, in relation to the cable "anchors", then cut 2 cable outers of equal length, then fit to the "twin" cables.
#5 fit the cable to the lever (do not tighten yet) and to the brake calipers (release the tension from the return sprins 1st)
#6 pull the cables tight towards the calipers, ensure all outers are seated correctly, then secure the nipples, but try to leave a few mm spare to allow the calipers to return to rest position when the brake is released.
#7 apply a little adjustment to the return springs to take up the cable slack.
#8 Screw the adjuster on the lever the midway position, then secure the cable (do not cut off the spare cable yet)
#9 Check brake operation, making any required adjustments (you may want to apply more or less spring pressure at this stage)
#10 When you are happy, snip off any excess cable and secure the cable "splitter" to the frame.
Hope I have not confused peeps too much, but this is long deliberated problem on my part, so I am happy with the result.
Ad  :daumenhoch:
Sanmarcopizza
Re: How to; Twin pull brakes problem solver.
« Reply #1 on: June 28, 2006, 07:41 AM »
Nice ! Just one question. Why ? You no likey straddle wire ? Oh OK, that's 2 questions.
« Reply #2 on: June 28, 2006, 09:26 AM »
one more question, why dont you like gyros?
a properly setup gyro is more effective than a single cable
Offline aditup2004
« Reply #3 on: June 28, 2006, 09:43 AM »
I ain't got no cable mounts on the frame to anchor the cable and I could not find any "bolt on" types for the correct size tubing.
The cable mounts you see are for the twin cable and are not in line to mount a bridge cable.
Ad  :daumenhoch:
Offline aditup2004
« Reply #4 on: June 28, 2006, 09:53 AM »
I hate Giro's, they give the brake a mushy, vague feel. Maybe if you spend a lot more money, they improve, but being a complete novice who can only just ride without stabalizers, I don't need a giro. (no bar spins here I'm afraid  :LolLolLolLol: )
Ad  :daumenhoch:
Andy
« Reply #5 on: June 28, 2006, 09:59 AM »
a properly set up straight cable is far superior to a properly set up gyro in my opinion
unless your barspinning like crazy an oddy slick or nokon cable minus a gyro will suit your needs
andy
« Reply #6 on: June 28, 2006, 10:00 AM »
the vagueness of a brake is often relieved by the double cable setup of the gyro!
just the standard gyro should be ok.
the reason why a gyro provides more effective braking, is because there is double the amount of cable
thats not an opinion either.
nice looking bike btw
Andy
« Reply #7 on: June 28, 2006, 10:04 AM »
ok, well i was just talking from personal experience, at the end of the day my straight run cable stops my bike perfectly
andy
Offline aditup2004
« Reply #8 on: June 28, 2006, 10:06 AM »
The bike was built from "cheap" parts I had lying around, or bought on the "cheap"
It is for a neighbour who had his stolen a few weeks ago.
His Uncle (also a neighbour) has helped me out a lot in the past, so it is a returned favour really.
It only stands me at about Ł70 as I got a lot of bits from a bunkrupt auction some weeks ago.
Ad  :daumenhoch:
« Reply #9 on: June 28, 2006, 10:12 AM »
thats the main thing
most modern bikes are "mid weight" now, so you dont have to eek every last n/m of stopping power out of your back brake. even a v brake will do!
back in the days of 45 pound bikes things were different.
but if you are keen on "ultimate stopping power" then run a gyro with twin lower cables.
also gyro cables are very well made, like the oddy slicks
Offline BrianP
« Reply #10 on: June 28, 2006, 10:19 AM »
yep, twin lower oddy slics with the wee gyro friendly nipples (huh huh, huh huh, nipples....) (not the linear version) and a dragonfly gemini upper cable.
works a treat and also real solid & responsive.
bp.
