976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 03:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Decals around fork corners - how do you do it? (With SOLUTION + Pic)
Author Topic: Decals around fork corners - how do you do it? (With SOLUTION + Pic)  (Read 2601 times)
0 Members and 6 Guests are viewing this topic.
punkdSICO
Hey all
How do you apply decs around the bend on forks?  Below is an extreme example where there would have been a major "crimple" at about the letter "D".  In the past I have cut out a thin triangle in the decal, one on either side.  I presume this is your only option?
Im doing decs at the moment and realised my fork decs are going to be like the above (not quite as extreme).
ta
Paul
SOLUTION
After a little googling, MM's suggestion below works (hair dryer).  This video shows the process:
http://www.youtube.com/watch?v=QO0Kjq6DPWk
I just used a hair dryer and a credit card, making sure you push outwards and dont make any creases.  I was lucky as I had a spare decal which I practiced with first.  The first real one was much better..
Thanks MM for the pointer..
Here are my results. You can see some small bubles in the picture but in the flesh, they really are not that bad and you would not notice.
Paul
« Last Edit: June 16, 2012, 07:20 PM by punkdSICO »
Offline Munnyella
Re: Decals around fork corners - how do you do it?
« Reply #1 on: June 15, 2012, 03:40 PM »
You don't have a problem with LG decals as they are `cut vinyl' rub on types, made up of loads of individual pieces, the carrier tape or film will flute up on application, but this is removed anyway.
A printed decal can be heated up with a hairdryer to aid stretching around a bend, but not easy.
MM
punkdSICO
« Reply #2 on: June 15, 2012, 03:57 PM »
MM
Hi - ta for the info on LG decs - I did not know that..
I dont fancy the hair dryer approach as in my experience, the problem lies with having a trianglular shaped too much vinyl crease.  Im guessing heating is good for stretching and getting getting extra shaping but not removing excess, like in the case where you are going around a set of forks..??
ta,
Paul
punkdSICO
« Reply #3 on: June 15, 2012, 05:16 PM »
Here is another pic where someone has done what Im trying to achieve:
Any thoughts?  Stanly Knife / hair dryer / something else??
ta
Paul
punkdSICO
« Reply #4 on: June 15, 2012, 06:15 PM »
Ive updated the first post to include my solution..
thanks MM..
Paul
« Last Edit: June 15, 2012, 06:17 PM by punkdSICO »
Offline Andy68
Re: Decals around fork corners - how do you do it? (With SOLUTION)
« Reply #5 on: June 15, 2012, 06:46 PM »
I gave up with my Jag decals, just couldn't get em to follow all the contours so ended up fitting em lower than I really wanted.
punkdSICO
Just included a picture of my attempt (top of the thread).  its not 100% but the picture makes it look worst than it is.  In the flesh, you would not notice unless being really critical..
ta
Paul
I find a bit of ass sweat from a young boy helps
punkdSICO
Im not exactly young but my butt is quite sweaty..  Ill give it a go next time  :)
Paul
Offline Andy68
That tin can looks like its about to topple over!!!   :shocked:
punkdSICO
yeah, it was a bit of a balancing act  :-\
Paul
Offline Munnyella
looks good.
I'll bet that TA has rub-on's instead of printed decals.
Use the hairdryer after you've done the straight bit, to heat and stretch the bit around the bend.
Some vinyl is also designed to shrink with heat, see vinyl wrapped cars!
MM
