976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 08:09 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing hard annodising
Author Topic: removing hard annodising  (Read 2147 times)
Offline kev-s
« on: June 22, 2012, 12:20 PM »
i know oven pride removes annodising (done it a few times)
but what about hard annodising, have heard that oven pride wont touch it, if so what will?
Clean
Re: removing hard annodising
« Reply #1 on: June 22, 2012, 12:54 PM »
Not really sure what "Hard Anodising" is, but it is probably a misnomer.  ::)
If an alloy is "Anodised" the process can always be reveresed using a strong alkali (eg Oven Pride); this is fundamental chemistry.  :angel:
I suspect that for "Hard Anodising" the anodised surface is over varnished with a lacquer of some sort to protect it; in this case you will first need to remove the lacquer, before resorting to Sodium Hydroxide / Caustic / Oven Pride to remove the anodised surface.  :daumenhoch:
Offline kev-s
« Reply #2 on: June 22, 2012, 01:00 PM »
just double checked and its "ultra hard annodising" :LolLolLolLol:
will do a test area with oven pride later :daumenhoch:
« Reply #3 on: June 22, 2012, 01:45 PM »
Stop pussying about with oven pride and get yourself some caustic soda.
« Reply #4 on: June 22, 2012, 05:03 PM »
X2   :2funny:
« Reply #5 on: June 22, 2012, 06:13 PM »
If it's a headset that you are trying to do ~ like a tange 300 or so then oven pride is fecking usless  ::)
haven't found any thing that will shift it, apart from polishing it out  :tickedoff:
Offline sawzall
« Reply #6 on: June 22, 2012, 07:08 PM »
caustic is the only way to remove hard anno kev,it takes ages but it will shift it,just keep checking
and use a scotch brite pad to rub item being stripped and dont forget some industrial rubber gloves and goggles :daumenhoch:
Offline jT Racing
  • i like bikes. :/
« Reply #7 on: June 23, 2012, 02:17 AM »
hard anno is just more anno if that makes sense. it's just a bigger layer.
ding dong
