976293 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 11:52 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Question about welding... calling all Sawzall's!!!!
Author Topic: Question about welding... calling all Sawzall's!!!!  (Read 1766 times)
Offline Redline
« on: June 24, 2012, 05:45 PM »
I have recently purchased an old alloy SE frame which has a small amount of chain rub on one of the rear seat stays... apparently typical on these frames.
My question is if I have it filled with weld and then dress it up, will you see a fine outline of the shape where it was welded as I'm planning to have the frame annodised and want to know whether it will show up or not?
Cheers for any advice dudes  :daumenhoch:
John
Offline HUTCHMAN
Re: Question about welding... calling all Sawzall's!!!!
« Reply #1 on: June 24, 2012, 06:02 PM »
no mate,with a bit of filing and re finishing it will dissappear.I've done exactly this on my straight stay ripper,on the drop outs. Were nearly obliterated by a freewheel fitted too close to the frame.
Offline Redline
« Reply #2 on: June 24, 2012, 06:03 PM »
Cheers fella  :daumenhoch:
Offline region11
« Reply #3 on: June 24, 2012, 07:03 PM »
I have the same small amount of chain rub on my ripper and to be honest once built up you dont notice it at all  :).
Neil
Offline Twesnik
« Reply #4 on: June 24, 2012, 08:36 PM »
Hmmmm,welding!
Itīs not about the filling,thatīs easy for someone who knownīs how to weld diff.materialīs!
Should known this,iīm a master-welder......
Itīs all about the kraftmanship after-wardīs!
« Reply #5 on: June 25, 2012, 07:42 PM »
they will have to use the exact same grade alluminium john, otherwise it will anodise differantly over the repair...
